Meelobee Posted August 22, 2012 Author Share Posted August 22, 2012 Thanks Mark Made a fancontroller in the right panel, just above the 7" touchscreen: I've also prepared the psu cover, a backpanel and a sidepanel for priming: And I've prepared a couple of parts for the 2nd layer of paint: Not a real big an update, all this stuff is very time consuming.... till next time! Link to comment Share on other sites More sharing options...
Meelobee Posted August 28, 2012 Author Share Posted August 28, 2012 Some of the parts after the 2nd layer of paint: Link to comment Share on other sites More sharing options...
shiryu_libra Posted August 29, 2012 Share Posted August 29, 2012 it's a beautiful work keep it up man Link to comment Share on other sites More sharing options...
frozensnail Posted August 29, 2012 Share Posted August 29, 2012 very nice work & I like how you have though about the fan controller in detail Link to comment Share on other sites More sharing options...
Meelobee Posted August 31, 2012 Author Share Posted August 31, 2012 Thanks Shiryu_libra & Frozensnail Painted the main parts of the frame: And started to rebuild the case with the painted parts (phone pics, sorry) Wired up the main powerconnector & On/Off switch. The blue cable is for the 7" touchscreen. Front bar = shiny! Link to comment Share on other sites More sharing options...
Meelobee Posted September 3, 2012 Author Share Posted September 3, 2012 I've almost finished the left sidepanel. Tonight I've installed the rads, the touchscreen and the fancontroller: The print with the on/off switch for the screen is on the left side of the bottom frame: Domenut as temporary button (any ideas what to replace it with?) Link to comment Share on other sites More sharing options...
Meelobee Posted September 7, 2012 Author Share Posted September 7, 2012 Not a single comment/reply? I've installed all the plexistrips to the frame (which also was painted) and I've installed the front and back side of the case: Link to comment Share on other sites More sharing options...
Ch2pa Posted September 7, 2012 Share Posted September 7, 2012 Not a single comment/reply? I think most of the people here just publish their worklog and don't take time to watch and comment other's. If they miss your worklog it's a shame: your work is very clean and your mod brings a lot of innovations! Keep up the modding level Link to comment Share on other sites More sharing options...
Fifas Posted September 8, 2012 Share Posted September 8, 2012 WOW! Just WOW! Fantastic work man! Awesome project! Link to comment Share on other sites More sharing options...
Meelobee Posted September 9, 2012 Author Share Posted September 9, 2012 Ch2pa: Yeah I guess so... ok back to showing off then Fifas: Thanks Did most of the sleeving in the case: Pump: Powersupply: Powerbutton: The half stripped case Almost done sleeving the psu wires with Paracord, unfortunately I ran out of white Paracord so there's still 3 wires left to do. Finally decided how to wire the gpu. So I've prepared for the wires of the gpu by making another hole in the panel that holds the mobo. (And I ordered another lasercut panel, just like the ATX panel. But this one is smaller and has 13 holes.) Early version of the gpu bracket, it's quite big and bulky, but it will be smaller/sleeker when it's done. And last but not least, a simple but effective bracket for 2 SSD disks. The second disk fits in between the 2 alu pieces underneath the other disk. And I've installed the ledstrips in the top of the case: I also have a small movie of the RGB leds in action, here is the link to the clip I made: http://youtu.be/e3CcBQAFuEw Link to comment Share on other sites More sharing options...
