Meelobee Posted September 18, 2012 Author Share Posted September 18, 2012 A couple of days ago I received the 2nd pass-through panel and with it I've finished the wiring for the videocard. The wires have been cut to length and have been sleeved with Paracord. The 13th (still empty) hole is for the wire of the powerbutton. And I've almost finished the mounting bracket for the videocard: Link to comment Share on other sites More sharing options...
Meelobee Posted September 22, 2012 Author Share Posted September 22, 2012 Took a while, but finally I got all the parts painted. Last 2 I needed to do where the left sidepanel and the GPU bracket. After painting I installed both. The black dots are the heads of the bolts that hold the parts on the inside, they won't be visible when the mobo is installed. The inside, it's gonna be a :) of a job to make everything fit and close the case. Sata, 24pins ATX (incl plugs) & EATX wiring all have to fit in there somehow.. Link to comment Share on other sites More sharing options...
Meelobee Posted October 10, 2012 Author Share Posted October 10, 2012 Link to comment Share on other sites More sharing options...
Meelobee Posted October 23, 2012 Author Share Posted October 23, 2012 It's alive! Small things to do: - Tidy up the GPU wires. - Make a backplate for GPU. - Install lights in lower part of case. - Sort the wiring for the 7" touchscreen under the radiators. - Make final pics. Link to comment Share on other sites More sharing options...
