HACKER354E Posted August 14, 2012 Share Posted August 14, 2012 Hi guys I’m HACKER354E and today I’m here to introduce my project called CUBO PROJECT. The CUBO PROJECT will not be a simple cube shaped PC, but a wealth of technology in old style. The CUBO PROJECT will include a home made device that will allow the cube to rotate at 360 ° without any limitation of cable. The cube will also be prepared for the use of your PC without a monitor as we anticipate the use of a small monitor tuchsreen [7"] on one side, but this will be an additional object. The Home Made device will be the real difficulty of this case. Now I leave you projects. I hope you Curious, and forgive my dirty English! This is the outer chassis.The cube measuring 340x340 mm and is constructed entirely of stainless. This is the basis of the rotating cube a detail of the ball bearing placed at the base mounting of the turntable at the base of the case this is the basis rotating view from below these are the brushes that allow the passage of the video signal and voltage from the base inside the computer. These are the base of the device made ​​by me these are the copper rings where they're going to swipe the brush. The white rings are insulated spacers that will be placed between the rings of copper. the brushes are fixed on a Teflon tube inside the pc. The rings will be fixed at a fixed tube at the base that will come up within the PC. here is a picture that can make the idea. I say sorry for my English. Stay tuned! From HACKER354E it's all! Link to comment Share on other sites More sharing options...
HACKER354E Posted August 23, 2012 Author Share Posted August 23, 2012 Hi guys Today I leave the side projects that I will fulfill in plexiglass. I'll make a laser engraved with the symbol MASTERCOOLER, the name of the project "cubo project" and my nick "HACKER354E." This is a vector image that will be used for engraving. This is the project of the side. And this is the form\mask to do a good and precise cutting on steel with the dremel . I say sorry for my English. Stay tuned! From HACKER354E it's all! Link to comment Share on other sites More sharing options...
frozensnail Posted August 23, 2012 Share Posted August 23, 2012 wow this looks industrial, Stainless steel construction? Very hard material to be cutting & drilling, wish you all the best with the case mod, like shiny mods:-) Link to comment Share on other sites More sharing options...
wwwicked Posted August 24, 2012 Share Posted August 24, 2012 Looks real nice, really am curious how the brush signal transfers are going to work. Also, don't apologize for your English, it's quite well . Will follow your build. Keep up the good work! Link to comment Share on other sites More sharing options...
HACKER354E Posted August 24, 2012 Author Share Posted August 24, 2012 wow this looks industrial, Stainless steel construction? Very hard material to be cutting & drilling, wish you all the best with the case mod, like shiny mods:-) oh thank you very much! even my old mod was built entirely of steel .. hard work! Looks real nice, really am curious how the brush signal transfers are going to work. Also, don't apologize for your English, it's quite well .Will follow your build. Keep up the good work! thanks very much! stay tuned! Link to comment Share on other sites More sharing options...
HACKER354E Posted August 26, 2012 Author Share Posted August 26, 2012 hello guys! I'm back with updates! The idea of the project is to realize a cube with sides all equal (with the same cut). Yesterday I made ​​the first cut, which will fix the power supply (600W COOLERMASTER PROSILENT). I cut the steel with the grinder following mask created earlier for a precise cut, after I filed to end it all. work and realized the cut. work while realizable cutting radius 130mm for the power supply fan. Link to comment Share on other sites More sharing options...
HACKER354E Posted August 26, 2012 Author Share Posted August 26, 2012 the final result.... PS: probably the colors of the cube is glossy white for the outside and carbon for sheets inside (the black sheet in the picture) PPS: I say sorry for my English. Stay tuned! From HACKER354E it's all! Link to comment Share on other sites More sharing options...
frozensnail Posted August 30, 2012 Share Posted August 30, 2012 that looks sweet buddy, lots of hard work cutting going on, I'll stay tuned for the updates Link to comment Share on other sites More sharing options...
HACKER354E Posted September 6, 2012 Author Share Posted September 6, 2012 Hi guys! I'm back with small update! This is the side in Plexiglas with the laser incision. This will be illuminated with BLUE LED strip. I like it. I want to see it mounted and illuminated I say sorry for my English. Stay tuned! From HACKER354E it's all! Link to comment Share on other sites More sharing options...
HACKER354E Posted September 8, 2012 Author Share Posted September 8, 2012 Hi guys! I'm back with update! Here is a list of HW components that ride on. CPU to decide, I think an i7 3770k. - Mother Board Asus Saberthoot P67 - Master Cooler Pro Silent 600W - Master Cooler V8 - Ati Radeon HD6870 Here the carbon that I will use to make the interior (black sheets) And finally some pictures of the HomeMade device here I am realizing the brush holder here I'm making the holes that will be turned into rectangles 6x5mm where it will put brush.I created a mask with holes spaced 3 mm between them once made the holes I made them into rectangles and after a good burr..this is the result. now the other part of the Home made device.the part fixed to the ground. These are rings with wires soldered with torch. After welding, I filed the pond in excess. Before After these are the spacers of Teflon the result that we obtain I say sorry for my English. Stay tuned! From HACKER354E it's all! Link to comment Share on other sites More sharing options...
