HACKER354E Posted September 9, 2012 Author Share Posted September 9, 2012 hello guys, today I have done and finished all the cuts on the case. below some photos I cut the long sides with the grinder while the corners with the dremel after an hour's work here is waste some random photos the final result I say sorry for my English. Stay tuned! From HACKER354E it's all! Link to comment Share on other sites More sharing options...
HACKER354E Posted September 14, 2012 Author Share Posted September 14, 2012 hello guys today I present the v8 I'm going to mount. I have limited myself to replace the red LEDs in blue LEDs. As soon as possible will post photos of the device hommade I say sorry for my English. Stay tuned! Link to comment Share on other sites More sharing options...
HACKER354E Posted September 15, 2012 Author Share Posted September 15, 2012 hi guys... today I present the new pedestal. I decided to change it again cause space and in fact the basis of this pedestal is twice as old. these are the brackets for MC V8 LGA 1155... This is the plan of starting and this is the result This is how the device is coming.Imperfections will be removed by setting the device ended up turning. This is HD cable to be welded to the device. From HACKER354E it's all I say sorry for my English. Stay tuned! Link to comment Share on other sites More sharing options...
HACKER354E Posted September 23, 2012 Author Share Posted September 23, 2012 good evening guys I'll post some pictures of the latest advances. I'm trying to finish the home-made device. Here are the brushes with the wires welded. From HACKER354E it's all I say sorry for my English. Stay tuned! Link to comment Share on other sites More sharing options...
HACKER354E Posted September 25, 2012 Author Share Posted September 25, 2012 hi guys... I puttied corners making them at 45 °. this is the monitor 7'' touchscreen I hope to finish the HM device by the weekend but I'm not sure. From HACKER354E it's all I say sorry for my English. Stay tuned! Link to comment Share on other sites More sharing options...
HACKER354E Posted September 30, 2012 Author Share Posted September 30, 2012 Hi guys! I'm back with update! here is the last shopping...Ram 16Gb CPU Intel i7 3770k & SSD corsair Force 3 120Gb I have a small space problem caused by the V8 but I think I have found a solution right now, tomorrow I will upgrade! I created the side where the motherboard will set ,the stepper motor was used as a weight;) Link to comment Share on other sites More sharing options...
HACKER354E Posted September 30, 2012 Author Share Posted September 30, 2012 I have also almost completed the base, I have to finish the details. I set the HDMI and the power outlet. From HACKER354E it's all I say sorry for my English. Stay tuned! Link to comment Share on other sites More sharing options...
MonsterMawd Posted October 3, 2012 Share Posted October 3, 2012 I'm intrigued about this project, great fabrication work with the Stainless. Link to comment Share on other sites More sharing options...
HACKER354E Posted October 11, 2012 Author Share Posted October 11, 2012 I'm intrigued about this project, great fabrication work with the Stainless. thanks friend honored that you like it. The Cube Project is not at the level of your mod but maybe I can do something similar. but by engaging (maybe) I can do something similar. However Thank you and.....sorry for my English hello guys. here is the new up! here's the supply side however this is the DVD slim carbon these are the screws that I will use. M6 stainless steel I also fixed the socket 220 From HACKER354E it's all I say sorry for my English. Stay tuned! Link to comment Share on other sites More sharing options...
HACKER354E Posted October 13, 2012 Author Share Posted October 13, 2012 Today I made ​​the first painting. the first of 4. From HACKER354E it's all I say sorry for my English. Stay tuned! Link to comment Share on other sites More sharing options...
