pcjunkie209 Posted October 31, 2012 Author Share Posted October 31, 2012 That is one cool paint job, air brushing looks great on the side panels. The red powder coating will give a good contrast between the colours chosen Thanks Frozensnail! I think It's time for an update tonite. Link to comment Share on other sites More sharing options...
pcjunkie209 Posted November 4, 2012 Author Share Posted November 4, 2012 Ok so it's time for an update on my mod. here we go!!!!! So a lot of pics. here's fresh back from clear coating. I started adding some hardware like the Excalibur fans I painted to match. Started to lay out some WCing parts. Installed the motherboard for placement of surrounding parts. FrozenQ res came in so finding a home for that and the pump. small space to have the cooling connecting but it will work Almost forgot FrozenQ is coming out with a new cpu waterblock. It will look similar to this. The one I have is the prototype. To the surrounding edges it will have acrylic with optional etching and such. EVGA GTX680's getting cooled 680's installed........ running the tubing for the wcing...... An the fun part filling the system for the first time. I used Mayhems light Red Pastel for this build. Thats it for now thanks for looking. Still a lot of work PSU needs sleeving and debating on copper tubing but may have to take out psu shroud for that. Decisions!!! Until next time. Link to comment Share on other sites More sharing options...
pcjunkie209 Posted November 7, 2012 Author Share Posted November 7, 2012 Ok so I have some more pics. I got this mod up and running for Sacramento Lanfest so I could show Evga what they got involved in. So this is most likely going to be reworked because I'm not too sure I am happy with it. Anyways on with the pics.......... I had some logos done. Karl Maser does excellent work! And what is a mod without the best from Nils!! For kicks I took it out for some sun and you can see the graphics better. That's it for now will be back soon if I decide to make some changes. Until then............ Link to comment Share on other sites More sharing options...
HULK Posted November 12, 2012 Share Posted November 12, 2012 Nice clean build. Keep it up. Link to comment Share on other sites More sharing options...
Alexander Hede Posted November 17, 2012 Share Posted November 17, 2012 stunning work! Link to comment Share on other sites More sharing options...
pcjunkie209 Posted December 4, 2012 Author Share Posted December 4, 2012 Thanks guys! Alright so I made a few changes to this mod. As you will see I decided to take out the sub-floor. I think it was a fare trade! I have been doing some reading about running copper tubing and finally made the plunge. I pick up a few tools and some 12mm copper tube to start playing with and decided to go for it. Here's some pics. I picked up a two handle pipe bender, a cutter and used my trusty MNPCTECH mod ruler to get accurate measurements.... While I had the board out I went ahead and took a couple more pics of the FrozenQ prototype waterblock... And here's how it came out... I also started on the psu..... Thats it for now. Thanks for looking. More to come. Until then...... Link to comment Share on other sites More sharing options...
Alexander Hede Posted December 4, 2012 Share Posted December 4, 2012 Really liking the copper tubes, glad you decided to keep modding! Link to comment Share on other sites More sharing options...
Ch2pa Posted December 4, 2012 Share Posted December 4, 2012 Very nice modding/painting job What kind of finish will you apply on your copper pipes? Link to comment Share on other sites More sharing options...
frozensnail Posted December 4, 2012 Share Posted December 4, 2012 Rigid tubing is a nice touch & takes some doing to get it looking good as it does here. Sure is a very clean water cooling loop! Link to comment Share on other sites More sharing options...
pcjunkie209 Posted December 6, 2012 Author Share Posted December 6, 2012 Thank you guys! I'm glad I changed it also FrozenSnail! I'm really digging this copper tubing and it wasn't that hard just a lot of thinking and planning to get it where it is. Thanks again guys!! More pics soon running out of time. Link to comment Share on other sites More sharing options...
