Dobrinhrkr Posted August 23, 2012 Share Posted August 23, 2012 Hello everybody, Few months ago I've decided to build a new project from scratch. The idea was for a small, stylish and theme based project for a slim case/stand based on mini ITX motherboard with as few as possible peripheral devices. The hardware used for this build so far is:Â Cooler Master Excalibur 120mm fan Elitegroup CDC-I (V1.0) picoPSU-80 SSD and memory ADATA 64GB SSD ADATA 2x4GB SODIMM DDR3 Now is time to thank my sponsors again: There was no scheme, no drawings, no lasers . Everything was in my head and was built by hand on the move. Here we go.. After I finished drawing and choosing place for the motherboard my camera betrayed me. For that reason I couldn't make pictures from the begining. First cut on the base platform: Few more cuts: Sanding the first platform: First platform at 30% ready with motherboard mounted: This is for now, more updates on the way: Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 23, 2012 Author Share Posted August 23, 2012 After I went back to my home tome for the fast 4 days(Easter celebrations) I've decided to use that time and work. Except the plastic, I was thinking to use aluminium or stainless steel plates but after all, the choice was aluminium. Cutting process: After I got some of the parts needed I had to invest a lot of time sanding them: Lets say they are ok, so it was drilling time With motherboard on: To be continue.... Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 24, 2012 Author Share Posted August 24, 2012 After I finished the first part, it was about time to work on the second: Before I started sanding the plastic, I've decided to drill and attach the aluminium plates, so they can be my guide while sanding. It was too late, but I did some sanding. Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 24, 2012 Author Share Posted August 24, 2012 New update: After I've mounted the aluminium plates to the plastic and finished sanding the part looks like this: First test with light: And both parts together: Meanwhile, Elitegroup promised to sponsor me with: Elitegroup CDC-TI (V1.0A) and Revoltec with RM131 and RM130. Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 25, 2012 Author Share Posted August 25, 2012 Ok... one more piece of the puzzle Today I had some free time and I've decided to make the second plate, which will be the base for SSD and CCL invertors. Its absolutely the same as the first one, but this time I've cut it faster and nicer. After I finished cutting and started sanding, an urgent job popped up so I will finish it other time. Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 25, 2012 Author Share Posted August 25, 2012 Before I continue with the project I want to show what parts I got so far: 1. The cold cathodes from Revoltec 2. The power and reset buttons: Ok here we go. In Bulgaria we had 4 days off from work and I used that time to go back to my home town and use our workshop: Last week I cut the second acrylic plate and I had to do some sanding and make the aluminium plates for it: I did those plates and I've decided to do some sanding on that acrylic plate. After 20 mins if sanding and my father watching me he decided to help with some serious machine sanding. After 2 mins the plate was complete and my ego was ruined: All parts so far: Next step was drilling the holes to mount the acrylic and the aluminium plates together: After those parts were mounted together I had to do again some small polishing to make them fit perfect: After all was done on that part my job continued with assembling those 3 full parts together and drilling the holes: The last step for that day was to drill the holes for the buttons: More pictures incoming Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 26, 2012 Author Share Posted August 26, 2012 I showed only half of the project's progress and it's time to show the rest of the pictures. After I drilled the holes for the buttons it was about time to assemble those main parts to see what they look like. After all parts were together, I decided to make the holes for the bolts bigger and increased their size from 3mm to 4mm. At the beginning of the project I was thinking to make it like 4 parts with some standoffs between those plates, unfortunately the regular long nuts with inner diameter 4mm were only 15mm long and that wasn't enough. For that reason my father took a new big and noisy machine and we had to cut some 27mm pieces from stainless steel: At the beginning we cut only 6 pieces at size 27mm and polished them with a drilling machine and sanding disc so I can mount those parts together: To be able to assemble both parts together I had to cut long bolts into different size smaller bolts and attach them with round nuts. After I had the first bolts and tubes ready I assembled the first parts together: Since the drilled holes in both plexi parts were more, my father cut a few more stainless steel tubes at 27mm and I prepared the bolts plus polished the tubes. After all the mounting parts were ready we installed the third main part of the project and all together they look like that: After all parts were together I had to install the plexi feet that I had bought a few days before. All parts were mounted together and the project looks like that: Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 26, 2012 Author Share Posted August 26, 2012 A small unofficial update with the lights. I say unofficial because I just had some fun and the lights are not ready yet. Enjoy Best Regards Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 26, 2012 Author Share Posted August 26, 2012 Been awhile since I played with lights and they looked quite nice, but really could not stay that way. Since the total thickness of plexi plus the two aluminum plates was 7 mm and the LED strip is 8 mm, I concluded that I should install the lights inside the plexi. After I installed the first LED strip I just had to test how it performs Once I finished the first part I did the same with the second platform on which the motherboard is mounted. Once it was assembled, it looked like this: Of course, I had to see how it looks assembled: Seems I turned the connector, but was too late. "Fear of the dark" Best Regards Link to comment Share on other sites More sharing options...
Dobrinhrkr Posted August 27, 2012 Author Share Posted August 27, 2012 While waiting for the motherboard to come, so I can make the fourth part of the project, I decided to work on the cables that I’m going to need. The first one I’m going to use is for powering the LED stripes. I needed to modify something, of course: The cable is meant for powering and regulating 3 fans but I cut out the regulating cable and modified it as a fourth power one: I had to apply some sanding the connectors: And then came the best part – sleeving: I had a SATA cable as well, so I sleeved it too: After finishing the cables, I took some pictures of the whole structure put together: Best Regards Link to comment Share on other sites More sharing options...
