maestro0428 Posted September 19, 2012 Author Share Posted September 19, 2012 I added a Folding@Home logo on my heatsink fan grill. Link to comment Share on other sites More sharing options...
maestro0428 Posted September 21, 2012 Author Share Posted September 21, 2012 I am so busy I barely have time to write this. The mod is nearly done...except for some new high performance coolers and I have much more to say. Stay tuned I will write something, I promise! -maestro from JAllen Labs Link to comment Share on other sites More sharing options...
maestro0428 Posted September 21, 2012 Author Share Posted September 21, 2012 Its 4:36 in the morning! Making time like I said I would right? Okay here we go. I blocked off the bottom holes from removing the grille and the back of the optical drive bays with black foam core. Sure I could use aluminum, but this is cheaper, easier to cut and even lighter. It looks good too. I did add an aluminum angle bar to the edge to make it look at home though. Clean look. Anyway, here are three pics of that work and one pic of the little fan I got to cool the mosfets. Ah, you're right I am missing the photo from the bottom area. Later I guess. Link to comment Share on other sites More sharing options...
maestro0428 Posted September 21, 2012 Author Share Posted September 21, 2012 I want to hide more of the wires, but the vga powersupply has to connect to the vid card somehow. I guess I could use black mesh instead of red, but I kinda like the red. Bah! Link to comment Share on other sites More sharing options...
maestro0428 Posted November 8, 2012 Author Share Posted November 8, 2012 I just purchased the new CoolerMaster Seidon 120M water cooler. I needed to cool my cpu down as I am folding@home on the cpu as well as the gpu 24/7 and the other cooler just couldn't keep up. When I got it all assembled, it didn't fit?! The AM3 socket cpu hold down screws were too short and the springs were too stiff. I looked at it a million ways and came to the same conclusion every time. It just didn't fit the socket I had. Of course, that may be a set back, but I wasn't sending it back, I was gonna mod it to work. First thing I did was cut the original springs off and replace them with shorter ones. The screws still couldn't reach the socket. Then I tried it bolted down with no springs. It worked, but it wasn't tight enough as I was hitting 60 C at 100% load on 4 cores. I placed some washers under the screws and that would do it. 47C at full load with stock 3.4 clocks. Not too bad now. Once I got the socket mount sorted out, I moved on to the fans. My push-pull set up with the red led fans were not pushing enough air. I switched back to the single, stock CoolerMaster fan and it does well at cooling. Next up, new 120mm LED fans that run at a higher rpm. Sorry for the crummy pics, I will post better photos when I get some more time. By the way, this machine is folding 29000 points daily at all stock clocks. Link to comment Share on other sites More sharing options...
maestro0428 Posted December 7, 2012 Author Share Posted December 7, 2012 Unfortunately time and money caught up with me on this mod. After several failures of hardware, it now runs stably 24/7 with a production rate of 28000ppd in Folding@Home. At some point I will have to mod the case, but for now, it does its job and looks good doing it. And the final photo Link to comment Share on other sites More sharing options...
