MooZ Posted September 18, 2012 Share Posted September 18, 2012 Keep on the good work bro! that black coat looks pretty clean and white wowww Link to comment Share on other sites More sharing options...
Toppy Posted September 18, 2012 Share Posted September 18, 2012 Liking this alot really good work there dude ...thumbs up Link to comment Share on other sites More sharing options...
Gusts Posted September 19, 2012 Author Share Posted September 19, 2012 frozensnail Thanks. I still need to improve the badge. MooZ Thanks Mooz! Toppy Thank you Toppy. So guys, the idea to fix the original fan is that: It will be an extension of the main part, but separating the fan. Regards, Gusts. Link to comment Share on other sites More sharing options...
Gusts Posted September 24, 2012 Author Share Posted September 24, 2012 Hello guys, this weekend I fixed the grills at the main body using resin and fiberglass Testing... I had some problems in the struct during the tests. So I need to make the paint again Maybe I'll change the black color for other Regards, Gusts. Link to comment Share on other sites More sharing options...
Gusts Posted September 30, 2012 Author Share Posted September 30, 2012 Hello everyone ...I did the final paint at weekend. Let's see... I saw that part loose. So I fixed again using resin. I took the opportunity to improve the Cooler Master badge that I forget to make first time. And painting again... Sanding the badge... I painted the inside part too And the fan I just have to make some things to finish the TxMod Regards, Gusts. Link to comment Share on other sites More sharing options...
MonsterMawd Posted October 3, 2012 Share Posted October 3, 2012 Wow, excellent intricate work with the acrylic! Link to comment Share on other sites More sharing options...
Gusts Posted October 3, 2012 Author Share Posted October 3, 2012 mnpctech - Thanks Bill! Does anyone know what this piece can be? Regards, Gusts. Link to comment Share on other sites More sharing options...
Gusts Posted October 5, 2012 Author Share Posted October 5, 2012 Hello guys, that is the idea... I made a long time ago, but I waited to show you Every pieces were made with dremel, sanding and patient Preparing to paint... Painted... That's it for now. Cheers , Gusts. Link to comment Share on other sites More sharing options...
Gusts Posted October 7, 2012 Author Share Posted October 7, 2012 Hello everyone, it`s time to iluminate The idea was put four 3mm white leds in the badge. Sanding the leds... I used a piece of plastic to isolate the leds and the cooler, and to reflect the light. I put a piece of tape in the badge to help the ilumination. The result : I'll use that simple sleeve in the cable. I've to take the final pics and test the performance. Almost finished! Regards, Gusts. Link to comment Share on other sites More sharing options...
Gusts Posted October 13, 2012 Author Share Posted October 13, 2012 Hello guys, During that week I took some final photos of TxMod, but first I improved the visual of the heatpipes: The TxMod ... And in my casemod...I did a test comparing the idle temps of TX3 original(or almost ) and TxMod: TX3 original: TxMod: Some others photos: Maybe I`ll still make a little modifications If you can see more pictures, you can visit my album at photobucket: http://s227.photobucket.com/albums/dd18 ... mod/TxMod/ Regards, Gusts. Link to comment Share on other sites More sharing options...
