Enigma8750 Posted September 11, 2012 Share Posted September 11, 2012 @Enigma8750 It was'nt my intention to imitate someone's work. dude i havent seen your project it's just that you registered first doesn't mean i copied from you, i don't even know you. It just happen that I love Ducati motorcycle and the color theme is RED a color very close to FERRARI. Don't worry dude my designs are far away with yours. the color may look the same though. So you claim to you never saw my build and you have 90 percent of every styling cue of my original build. Wow.. We must be Connected in some way. Good luck to you Sir. Link to comment Share on other sites More sharing options...
patrick tamayo Posted October 1, 2012 Author Share Posted October 1, 2012 update disassemble the case remove front and side panels remove the front switch panel for sleeving FTW sleeves!!! Link to comment Share on other sites More sharing options...
patrick tamayo Posted October 1, 2012 Author Share Posted October 1, 2012 8 pin extension sleeving Link to comment Share on other sites More sharing options...
patrick tamayo Posted October 1, 2012 Author Share Posted October 1, 2012 CM fan and Airflow Sleeves Link to comment Share on other sites More sharing options...
patrick tamayo Posted October 1, 2012 Author Share Posted October 1, 2012 Front Panel Switch remove and Sleeves Link to comment Share on other sites More sharing options...
patrick tamayo Posted October 3, 2012 Author Share Posted October 3, 2012 Finished product hehe Link to comment Share on other sites More sharing options...
patrick tamayo Posted October 3, 2012 Author Share Posted October 3, 2012 Build my acrylic bench test while modding the case so i can use the computer Link to comment Share on other sites More sharing options...
frozensnail Posted October 3, 2012 Share Posted October 3, 2012 good job on the cables & the concept of the mod is coming along well, n1 Link to comment Share on other sites More sharing options...
MonsterMawd Posted October 3, 2012 Share Posted October 3, 2012 DUCATI theme FTW! ..... lookin good Link to comment Share on other sites More sharing options...
patrick tamayo Posted October 4, 2012 Author Share Posted October 4, 2012 Thank you sirs really appreciate your comments Link to comment Share on other sites More sharing options...
