Jump to content
[ Scratch Build ] Dead Space CPU with DIY Projector
kartner
Hi Guys,
This will be my First CPU Mod Hope you enjoy it :)
I'll be building a CPU with a DIY Projector Inside.
Themed on my favorite Game Dead space.
I'll be updating the first page of this post as I Finish Parts
For those who are not familiar wit DIY Projector
This is a projector wherein you use an extremely bright lightsource, a couple of Lenses and a LCD Monitor, screen can be as big as 100" to 150"
more Here for technical description: http://z6.invisionfree.com/diyprojector ... hp?act=idx
Link to comment
  • Replies 29
  • Created
  • Last Reply
Here are my Major parts list... minor parts to be added as built
Qualifier: Cooler Master 212 CPU Cooler
PC I bought:
Mother Board:
Video Card:
Processor:
DVD drive: ( I may or may not put this in depending on space requirements)
power Supply:
120 Radiator: ( might just use an aquarium pump due to budget constraints)
Projector parts:
LED, 10.1 LCD and Lenses
Logitech Wireless Keyboard and Mouse
wireless xbox controller
x Mini
Time to put on my thinking cap and start the design :)
Link to comment
Mounting the LCD to its frame
For DIY Projectors you would need to remove the LED back light of the LCD
First I removed the stickers at the sides, top and bottom
Very carefully remove the Sticker with " Dont touch written on it" use a thin screw driver,
Take Utmost care used in handling the board and LCD especially the connecting Ribbon...
once thats damaged your LCD is dead...
the board is double taped to the LCD, CAREFULLY pry it apart
remove the LED backlit power
Pry open the metal enclosure of the LCD and remove the LED back light
It should look like this apart
Link to comment
  • Create New...
Important Information
