kartner Posted October 6, 2012 Author Share Posted October 6, 2012 I've changed the layout of my parts quite a bit Here's the updated plans I've also finished some work for the CPU Case lasercut and sanded the acrylic for a frosted effect Used extra screws from the Hyper 212 EVo to hold the motherboard, Since this was my first build for a CPU I've spent a lot of time making sure the holes would align with the motherboard, I/O, Video cards and Slots, Thankfully they did Link to comment Share on other sites More sharing options...
kartner Posted October 10, 2012 Author Share Posted October 10, 2012 I'm having a lot of problems with the backing leaks all over the place so i've decided to change the backing of the LED completely here's the new backplate, glued to the acrylic directly instead of screws the front of the LED, there were also leaks on the front, fixed with sealant. I didn't experience this on previous builds, looks like the LED itself has minute holes from manufacturing Link to comment Share on other sites More sharing options...
kartner Posted October 17, 2012 Author Share Posted October 17, 2012 Alright some progress atlast!! I used sealant on the source of the leaks, the water is hitting the LED heatsink, however the LED itself was the cause of the leaks, Sealed up all white parts in picture below Link to comment Share on other sites More sharing options...
kartner Posted October 17, 2012 Author Share Posted October 17, 2012 Made and initial layout in paper, for test fitting the parts Some Used plastic I have lying around... 10mm thick, Its thicker that I would prefer for the casing however Its free and available... so Recycle cutting on my laser cutter \m/ cut parts Link to comment Share on other sites More sharing options...
kartner Posted October 17, 2012 Author Share Posted October 17, 2012 Assembled case carcass, Will paint this at some point side panels hasn't been made yet Here's the test of the projector parts... all working and NO water LEAKS!!! haha initial Images with Light leaks from the projector ( since casing hasnt been painted yet) Link to comment Share on other sites More sharing options...
kartner Posted October 20, 2012 Author Share Posted October 20, 2012 Making the side panel Cut out some sticker to block the paint Painted back portion metalic black Link to comment Share on other sites More sharing options...
kartner Posted October 27, 2012 Author Share Posted October 27, 2012 Lighting for the side panels Painted the casing metalic balack on the first layer, followed with dull black on the 2nd layer Link to comment Share on other sites More sharing options...
kartner Posted November 6, 2012 Author Share Posted November 6, 2012 made additional holes for the switch and plug Link to comment Share on other sites More sharing options...
kartner Posted December 7, 2012 Author Share Posted December 7, 2012 custom built Hard disk case LCD board controller, LED Transformer, Enclosed water pump Internal components Link to comment Share on other sites More sharing options...
kartner Posted December 7, 2012 Author Share Posted December 7, 2012 modified Hyper 212 in action... Working PRojector with CPU... Link to comment Share on other sites More sharing options...
