MACIEL BARRETO Posted September 6, 2012 Share Posted September 6, 2012 One of the biggest enemies of BATMAN ARKHAM CITY, returns now to try to stop BATMAN, in the world of PCS. JOKER MOD has been a new line of casemod, already known and produced by MACIEL BARRETO. Where datalhes and finish, make a difference. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted September 8, 2012 Author Share Posted September 8, 2012 This is the initial idea. I thought of doing something different, this idea arose. Then I began to production, using clay to model and head of villain. I used several references to a make the details perfectly. Here he is looking like ta punk. kkkkk Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted September 10, 2012 Author Share Posted September 10, 2012 now using silicone to copy the model preparing to put plaster. after applying several layers of silcone, made ​​one cut and go head demold Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted September 12, 2012 Author Share Posted September 12, 2012 Now ta time to open the form of silicone. After the plaster dried and silicone, will open for only now working with fiberglass. I do notice a cut in the back of the head, to exit with ease. here to see the already separating the silicone clay, then you copied the details. Link to comment Share on other sites More sharing options...
kharr Posted September 13, 2012 Share Posted September 13, 2012 man, as always, your works are still awesome as always!!! keep it up=) Link to comment Share on other sites More sharing options...
Tortured_soul Posted September 13, 2012 Share Posted September 13, 2012 Excelent work my friend and master. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted September 21, 2012 Author Share Posted September 21, 2012 Here ended the piece in fiberglass, taking the form of silicon, can make as many heads want. I took a picture in my head that I modeled, just to see how it would be, is getting very good. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted September 26, 2012 Author Share Posted September 26, 2012 Now I will make the body of JOKER, I will use Isopor spend less clay. : D: D here is already well underway. trunk ready, I can do so. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted September 26, 2012 Author Share Posted September 26, 2012 man, as always, your works are still awesome as always!!! keep it up=) Thank you my friend, I try to do the best possible within my limitations. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted September 26, 2012 Author Share Posted September 26, 2012 Excelent work my friend and master. My great friend tortured, is a time you met him, that person estraordinaria and talented, a single heart. Link to comment Share on other sites More sharing options...
