oldman Posted October 24, 2012 Share Posted October 24, 2012 I will be brief: WOW! Link to comment Share on other sites More sharing options...
ax0 Posted October 24, 2012 Share Posted October 24, 2012 Looks great so far. Nice job Link to comment Share on other sites More sharing options...
mindphaser7 Posted October 30, 2012 Author Share Posted October 30, 2012 Fitting the lid sidewall: PSU and hinge determine case minimal width: Lid frame in progress: Case frame and lid together (not fixed yet): Lid front panel: Link to comment Share on other sites More sharing options...
mindphaser7 Posted November 2, 2012 Author Share Posted November 2, 2012 Resizing furniture lattice for top vents: Grating attachments: Install grating on the side wall together with the exhaust turbine: The side walls painted inside at the same color as an aluminum frame: Link to comment Share on other sites More sharing options...
mindphaser7 Posted November 12, 2012 Author Share Posted November 12, 2012 It's time to start making video card housing. 3D model it’s good, but need to check the actual layout and dimensions. Natural size mockup from cardboard: Place a video card inside: Cut from fiberglass side parts of the housing. Aluminum darby will determine the angle between the sidewall parts during assembly: Side parts assembly via pull-out rivets: Aluminum softer then fiberglass so its easy to flush rivet heads: Mark holes for GPU-fan intake air: Painting and assembling: Looks like a coffin Link to comment Share on other sites More sharing options...
mindphaser7 Posted November 20, 2012 Author Share Posted November 20, 2012 Lets make front part of video card housing: Use an aluminum box-shaped profile: One of these turbines will be installed inside: So I have to give it a breath of fresh air, mark the holes: Drilling holes Ream a holes Use an aluminum darby: Hand made perforation: Top parts: Adhesive tape assembly: Front part: After a while: Cut away the needless edges and sanding: Final assembly: Link to comment Share on other sites More sharing options...
mindphaser7 Posted November 22, 2012 Author Share Posted November 22, 2012 Back to the “coffinâ€: Finally, after many hours of adjusting parts, video card housing installed on the guide mechanism and tested in action: Now assembled frame with cover just hard to hold in hands and there is no normal position for its storage, have to immediately make a table mount: Link to comment Share on other sites More sharing options...
mindphaser7 Posted November 28, 2012 Author Share Posted November 28, 2012 To keep at least some element of intrigue, I will not specify which item from the world of Half Life 2 was the inspiration object Basic set of material … and a baby carriage ?! Not all of course, only covers from the wheels Cutting, sawing, drilling Meanwhile another staff - find a paint for outside surfaces Link to comment Share on other sites More sharing options...
mindphaser7 Posted December 2, 2012 Author Share Posted December 2, 2012 Let's continue table mount making process… Since intrigue failed - just a screenshot I don’t really know what is it. Something links to the security screens in the Combine armory. Billets for "legs" from the aluminum angle Front support for legs Cool stuff Frame complete Link to comment Share on other sites More sharing options...
mindphaser7 Posted December 4, 2012 Author Share Posted December 4, 2012 The DVD-box assembly process. Titan’s blower need to be modified - have to reduce its length and cut through inlets for intake air. Disassembly and cutting: Going back. Reposition the motor stator: Approximate position in DVD-box: Air inlet: Test assembly: Now I work in a bathroom too Prepare to sort components: My inspiration: Closer view: Link to comment Share on other sites More sharing options...
