Jump to content
[Scratch Build] Project Simodd - Finished
Fifas
Hi guys,
First, let me say I'm sorry for my English. Not that good :oops:
Let's begin. So, explaining the strange name. Simodd - Sim Modd aka Simulator Modding. Strange, but not that hard to understand (need a better name :D)
One more thing, I'm sorry for the photo quality, but I don't have a good camera :(
Now, to the presentation. After my first mod I wanted to make something different. Something crazy! So I planned a Scratch Build Project.
Because I'm a Sim Fan, I planned something where I can put my G25 and play without fear of breaking my tiny desk one more time. So I started building a cockpit!
The design doesn't have anything new, but I build it at my way, with small details that make it unique!
And here, the first prototype almost ready, as you can see
And then, i took it to my room to a "test fit"
And then, painting, and last details...
The seat was removed from an old car and then repaired with new cloth.
After some time 'playing' with my new toy, I decided to take it to the next step. changing what's not that good, and making the last details
First, a Sketchup design.
And now, the hardware. It's not that great, but I don't have money for a new one :P
CPU: Intel P Dual Core E5300 @ 3.06GHz
MB: ASUS P5K Deluxe Wifi/AP Edition
RAM: 2x Corsair XMS2 1Gb + 1x Kingston 2Gb
VGA: ATI Radeon HD5850
HDD: Hitachi 250Gb + Western Digital 500Gb
Sound: Creative Audigy 2ZS
PSU: LC Power LC6550 V2
Starting with the hardware mod/tweaking for better looks
CPU Block Before
During:
And After:
Placed:
And these are the connectors I'm using:
And now a little more paint work
Don't forget the mainboard coolers :D
After:
Before:
After:
And a small detail in the board...Before:
Sanded:
And after (Blue LED)
And a test fit in my old case:
And then, I did a little test in the CPU Block. I didn't paint the sides of it, so it looks cool with a LED
And finally, I've started building the case for the hardware! This was build in Foamed PVC, because it's really light, and easy to work with. This case will be placed inside the seat 'base' (don't know how it's called :grr: )
Cutted pieces
And a important thing. Measure once, cut twice....oh wait :D
The only piece I didnt build...
Planning....
And finally, the fans I'm using! Cooler Master SickeFlow Blue! Really awesome and beautifull fans :wink:
More photos to come.
Thank you for watching!
Link to comment
  • Replies 31
  • Created
  • Last Reply
Hey great idea & nice job of pimping up the mobo, like to see more as the work continues
Thanks man :)
A little more progress...
Start working on the sleeving.
Did a "HDD mounting" (sorry...don't know how it's called :P ) and start testing the hardware...
And finally, the wood work on the seat base started.
And here, just to show the margin of error with the PSU :P
Finally, a little detail in the hardware window. A small dent in the wood for the acrylic
Link to comment
More progress. Hole for 3 120mm Fans in one side (I will not use those fans. They are just for testing.)
In the other side, preparing begins for USB and power/reset buttons
And finally, paint preparations began
And here comes one of that moments I completely forgot about everything else. It was thursday, and I'm trying to prepare everything to get to one LanParty on Friday. Painting and everything.
Challenge accepted, but i forgot about detailed pictures...SORRY! :(
Before going to the LAN, made a quick test, only to be sure everything works
And prepared some last details.
Link to comment
As I said before, I did this with the objective of going to a Lan Party here in Portugal, so I assemble everything and went there. The project isn't finished, but here's the pictures of it in the LAN Party.
For my joy, I win first place in modding contest :D
Here you can see the side USBs and Buttons. (also, Faboya's awesome project by my side :P)
Here is a small detail. In the front of the build, I connect a Power and Ethernet cable, and everything it's connected inside :D
Now that I have more time available for the build, I will disassemble it and finish the interior. With detailed pictures :P
Link to comment
Houston, I think I got a problem.... :P
So, today i heard my water pump making weird noises. Disassemble the case and found this:
The wood used in the base is all ruined. I had planned to rebuild the base in a simpler way, so it is not a serious problem.
Link to comment
So, while I do not find any wood to rebuild the base, I disassembled everything and started working on some details, and doing some maintenance .
First, removed the connectors in the front of the cockpit for remaking the electrical installation. As I said before, I only have a connector to power and LAN in the front. Everything is connected inside the cockpit.
here with the LAN connector
Next, did some work in the cuts for the cables in down side of the base. Here will go the PSU, LAN, VGA and USB cables to the Mainboard
Little detail in the front, for the cables go up
And with the carpet.
Next I decided to rebuild one side of the "interior case", because it was not good
Now, just for showing, the side of the case, with the USB and button holes
My buttons
And placed!
Now, this is not related to the MOD itself, but decided to do a little maintenance and a mod to the G25 gearbox
Started from disassembling it
Removed the spring and that little ball
And put a little spacer behind the spring for giving it a little streng
And next put some Heat-shrink tube in the ball. This way you dont listen that loud "click" that the gearbox does
Then started the assembling
Really better feeling than the original!
Next decided to clean my pedals. Latelly,I've noticed some "spiking" in my brake, so let's have a look. Removed them from the base
And after 3 years of abuse, I think I understand why they started the "spiking" :D
Poor pots :P
So, after all that mess cleaned, assembled everything
And last, did some soldering.
This will have the power to the PSU, and will have a hidden power strip for the G25/Monitor
I know this was more like a maintenance post, but it's kinda related to the mod :P
Link to comment
Thanks m8!
The only problem of taking it to a LAN it's is weight and size. This is freakin heavy :mrgreen:
I did all the cockpit in a "modular" construction, so this way, i can separate it in 3 parts and transport it :P
And Today I did a little more work
Found this connectores for the PSU cable
One side done!
Then, found this pieces for fixing the cables in the down side of the base
And started assembling the front
Then I did a little hole in the pedal base for passing the cable to the top
And continued with the assembling
At the end of the day, still had a little time for disassembling the g25 and do some maintenance
And found this gift
The cover of the gears is broken. I think I'm a little brute with the force feedback :mrgreen:
Link to comment
  • Create New...
Important Information
