Gusts Posted September 17, 2012 Share Posted September 17, 2012 Very interesting idea and nice work! Congrats Link to comment Share on other sites More sharing options...
Paladin | Patrick Posted September 19, 2012 Author Share Posted September 19, 2012 Poor GTX Not sure if it's gonna work very well now Good work until now, I like the idea. Will you use the IGP or another "full" gfx card? I also have a suggestion for you: you could paint in red all the cut edges to highlight them. Thanks. I do not know yet if I use the onboard graphics or a fake Sli do The one with the red edge I've ever considered, but then it is no longer acting as noble as if the edges are polished. Today I thought I once made ​​the next cut. Since the graphics card is below the upper section they are seen only bad. Therefore, I will later make a cut. This was the first idea, but to me not so liked... ...so I've from this picture... ...and this... ...the here done with a photo editing program. What do you think? Then I taped a second cut. In the top is a HDD bay. I would edit a HDD and poke it in So, what do you think fits ... so? Do you have any other suggestions? Link to comment Share on other sites More sharing options...
Paladin | Patrick Posted September 25, 2012 Author Share Posted September 25, 2012 Today there are only a small update. I now have the last two holes made ​​in the case. Then come now all the details on the hardware. Now I wait for the parts of the watercooling First, I have again the board was a little revision, then release it Link to comment Share on other sites More sharing options...
Paladin | Patrick Posted September 26, 2012 Author Share Posted September 26, 2012 On Friday, a nice package of Aquatuning has arrived. Many thanks again to this place for it. Some will make the heart bleed now when they see what I do with this stuff One half of the radiator is closed down. The water then passes purely on one side, and back out on the other side. The direction of opening the channels are then soldered. Mark first ... ...and cut. A channel I have been honing their length. The material was then so thin that was nothing more, so i just put a zip tie in the channel. I have sometimes made ​​a connection. First stuck and then cut with the angle grinder and polished. So, that's it again... Link to comment Share on other sites More sharing options...
tnecniv102 Posted September 28, 2012 Share Posted September 28, 2012 i think i'll gonna cry every time you cut those brandnew PC parts... btw very unique nice MOD dude! suggestion... i think you should consider using WATER JET for cutting those... Link to comment Share on other sites More sharing options...
