masbuskado Posted September 18, 2012 Share Posted September 18, 2012 Welcome to another excited and unique work log... Today we present to you RTL (Ready to LAN) a fully equiped Computer that you will be able to carry as a back pack for your next LAN Party. RTL will be build around the Cooler Master ELITE 120 Advanced and CM Storm Gaming Gear. It will have a Desert Camouflage Theme. So far the idea is to keep it as light and transportable as possible. It will house a powerful gaming system that eventually will be water cooled for better performance. Thanks to Cooler Master for trusting in us to accomplish this magnificent project. Special thanks to Mike Sonntag from CMS (Computer Modding Supplies) for sending us the U-Channel. Idea and Execution: masbuskado Location: New Mod City - New York Start: August 24, 2012 End: Parts for this Projects: ELITE 120 Advanced [Case] - On its way to NMC Silent Pro M 850w [PSU] - Arrived QuickFire Rapid [Keyboard] Arrived Sickleflow 120 [120mm Fans] Arrived SONUZ 530 [Headset] Arrived U Channel [Molding Edge] Arrived (Courtesy of Computer Modding Supplies] Desert Camo Shoulder Straps - Arrived Desert Camo Waist Pad - Arrived 100' Desert Camo Paracord - Arrived Gaming Mouse [N/A] 1155 ITX Motherboard [N/A] 1155 i7 Proccesor [N/A] Solid State Drives [N/A] DDR3 Memory [N/A] Slim Optical Drive [N/A] AMD or NVIDIA Video Card [N/A] CPU and GPU Water Blocks [N/A] Radiator, Pump and Reservoir [N/A] Fittings and Tubing [N/A] Fan Controller [N/A] Stay tuned for updates! Link to comment Share on other sites More sharing options...
masbuskado Posted September 18, 2012 Author Share Posted September 18, 2012 I found this suitcase in a goodwill store nearby and it only cost me $10... These are the only parts I need from the suitcase... was thinking on using the recessed wheels but the frame is made out plastic so instead I ordered a pair with metal frame. 100 Feet of Desert Camo Paracord... it gonna be a fun afternoon... Time to sleeve! Link to comment Share on other sites More sharing options...
masbuskado Posted September 18, 2012 Author Share Posted September 18, 2012 DAY ONE Mission: Sleeving Power Supply Subjet: Cooler Master Silent Pro M 850w w/ Desert Camo Paracord Stay tuned for More! Link to comment Share on other sites More sharing options...
masbuskado Posted September 18, 2012 Author Share Posted September 18, 2012 Cooler Master ELITE 120 Advanced Link to comment Share on other sites More sharing options...
masbuskado Posted September 18, 2012 Author Share Posted September 18, 2012 I decided to replace the PSU grill for a custom made PSU Fan Cover (grill) converter 135mm to 120mm with an Army Star as the main theme. Check this out and let me know what you think! Are U Ready to LAN? Link to comment Share on other sites More sharing options...
MoMod Posted September 18, 2012 Share Posted September 18, 2012 so far so good bro keep up the good work Link to comment Share on other sites More sharing options...
CM_modder Posted September 19, 2012 Share Posted September 19, 2012 Looks awesome so far! Link to comment Share on other sites More sharing options...
