steff345 Posted October 15, 2012 Author Share Posted October 15, 2012 Update time! I now cut the left side panel and did its initial mounting with piano hinges: The edge of the door is warped a bit - but this would not be a problem since the excess is going to be trimmed out anyway Next, I attached the angled block of wood to the side. Note that the edges are quite rough and needs smoothing and a bit of attention: I plan on cutting the door edge at an angle of 45 degrees to continue the length of the angled side further. A view of the door closed and the edge which is to be cut as described above. Link to comment Share on other sites More sharing options...
steff345 Posted October 15, 2012 Author Share Posted October 15, 2012 A view from the right panel side: My pet cat has found something new to rub her tummy against hehe and there she is - watching me while I work (I just couldn't resist posting this up) Link to comment Share on other sites More sharing options...
steff345 Posted October 21, 2012 Author Share Posted October 21, 2012 Hi guys, time for another update!! Started working on the base for the case. I plan on having it elevated by approximately 5 mm. Still a work in progress and must build upon this and will hopefully go well with the theme. Here, I cut a 45 degree angle, leaving 3mm height vertically from the base: I paused working on the base next so that I could cut the length after attaching both doors to the case, just to be sure I get the exact length without regretting cutting too earlier. So now I started wokring on the front panel which would house the USB and Audio ports. This is where it is to be fixed (I drilled 3 mounting holes in the front angled-cut): The piece of wood had to be two pieces attached side by side with a 5mm cut on one end so that it sits flush with the external panel (the glue is yet to dry up under the screws): Here's a better view of the 5mm cut: A view of the front side of it (needs sanding and a bit of attention): That's it for now! Thanks for looking! Link to comment Share on other sites More sharing options...
steff345 Posted October 21, 2012 Author Share Posted October 21, 2012 Next, I fixed the several strips of 10mm x 10mm pieces of wood (to make up the blinds for the open-air design) to the right side panel. Came out pretty well, but needs a bit of attention and sanding to be perfected: A cut had to be made on the door, so that the door could be opened freely without hitting the front panel: That's it for now Link to comment Share on other sites More sharing options...
Alex Ftoulis Posted October 21, 2012 Share Posted October 21, 2012 Pretty interesting concept my friend, good luck with the execution!! Mod on! Link to comment Share on other sites More sharing options...
steff345 Posted October 26, 2012 Author Share Posted October 26, 2012 Pretty interesting concept my friend, good luck with the execution!! Mod on! Thanks, and glad you find the concept interesting! The idea is a semi-open air/water cooled chassis, combining the 'best of both worlds' into one versatile package Link to comment Share on other sites More sharing options...
steff345 Posted October 28, 2012 Author Share Posted October 28, 2012 Time for more progress! I now cut the top panel to accommodate the 240 rad: The edges are still rough as they need to be attended to. I took the photos while the cut was quite 'raw' A front view of the top panel now, after the cut: I also had to cut a 2mm slice in the back panel to ensure a smooth fit of the rad. Again, this needs a bit of sanding to smoothen it out, so please forgive the rough edges: Next, I worked on attaching the front panel to the case, as you can see, it came out quite well (much better than i hoped at least ) : Link to comment Share on other sites More sharing options...
steff345 Posted October 28, 2012 Author Share Posted October 28, 2012 I then focused my attention of fixing the hinges on properly. For this, I had to cut a few grooves on the back panel, else, that nail heads would make contact with the panel and offset the door a little, causing a bit of gap between the door and the frame of the case. The grooves were cut out with a utility knife: A view of the cut groove: This was repeated for all 5 other hinge mounts as well: Once all 6 hinges were complete, I worked on finishing the base. Here's a view of the angled cut: And the final finished base: and until next time, adios! Link to comment Share on other sites More sharing options...
Alexander Hede Posted October 28, 2012 Share Posted October 28, 2012 Cool build! Link to comment Share on other sites More sharing options...
steff345 Posted November 5, 2012 Author Share Posted November 5, 2012 Cool build! Thanks! Glad you like it! Link to comment Share on other sites More sharing options...
