Jump to content
[Scratch Build] Spyder
Rhaikel
  • 1 month later...
Design for the base and legs
Chassis when it was still unpainted
shots with the mobo tray attached
Sorry for posting the finished product it’s hard to take pictures while working
Mount for radiator
base for my case including the mounts for radiator
now to start assembling the base of my case :bounce:
Spider's Arse :oops: (will show the design of PSU mount later on :) )
Now back to assembly
Finally installing the radiator, I’ll be using 140rad to cool my CPU and board
Link to comment
Luckily a friend of mine gave me an old motherboard tray from his case :D saves me a lot of time making one and i found a cool logo from the internet that would look cool on my build
adding red cabon fiber sticker
Showing where the hard disk is located
the logo that i got from the internet, made of stainless steel :)
Lights on
Link to comment
Now on to my main components ^_^
I’ll be using a 120mm fan from Coolermaster for my PSU
(Installing the fan to my PSU)
And it works :bounce:
I’ve made a custom shroud for my board to protect it since I’ll be using an open case
Found a stainless mesh lying around the house
Removing the heat sink of the board
Link to comment
Now time to make a custom-made water block for my board and processor
mosfet.jpg <<<< mosfet block
cpublock.jpg <<<< processor block
chipset.jpg <<<<< north bridge block
implementing it on CAD
I can’t find the photos of my mosfet block and north bridge block :?
Might as well show this than show nothing :cry:
Now for the bridge connecting the mosfet to the north bridge and the north bridge to the CPU
and then bake it
these would be the screws that i would use to connect the blocks
now to test fit them
And finally, to chrome the blocks (did i mention that I'll be using a coolermaster bracket for this :) )
Link to comment
This would be the bracket that ill use for PSU
Also want to share my DIY shroud for my video card
Now to make my Spyder's bling and cover for my fitting :D
Sample of his bling
Cover for fitting
Also made a custom shroud for my sound card and also will use the sound card to mount my SSD
ssd mounted to the sound card
This will be the base the i connect its fangs from the chassis
Link to comment
Custom reservoir I made
Sleeves for PSU, thank you FTW for these awesome sleeves
A before and after shot (sort of)
And also a shroud for my SSD, which was made by Tantric also a participant here (Thank you sir Mhike of Tantricmodz)
Installed a stock AMD fan for my G skill ram cooler
Bracket for my PUMP
Link to comment
And finally time to assemble the PC
Installing hose from reservoir to rad to pump
Placing the board and the blocks
Here is a view at the back of the board tray (messy wiring)
Forgot to mention that i also used a sentry fan controller for this
Link to comment
  • Create New...
Important Information
