Jump to content
[Case Mod] HTPC modding Cooler Master Elite 120
ArtX38
PC Components :
Case - Cooler Master Elite 120
Power Supply - Thermaltake TR2 RX 550W
Motherboard - Gigabyte GA-Z77N-WIFI
Processors - Intel Core i5-3570K
Memory - Corsair Vengeance Blue 8GB (2x4GB) 1600MHz
Video Card - Asus Radeon HD 7850
SSD - OCZ Agility 3 60 GB SATA III
Fan – 2 x Scythe Gentle Typhoon 120mm 1200rpm
Veris Multimedia Station Premium
Water Cooling Component:
Koolance CPU-370 (CPU)
Koolance CHC-125 (MB)
Koolance RAM-33 X 2
Koolance RP-401X2 Single 5.25" Reservoir
Koolance Water Pump PMP-400 High-flow Pump
Koolance Radiator, 1x120mm 20-FPI Copper
Koolance Liquid Coolant
http://www.youtube.com/watch?v=_bVwhGWZZb4&feature=channel&list
Cooler Master Elite 120 sound of the fan.
A large microphone background
1 meters away nothing is heard
http://www.youtube.com/watch?v=Ukmo9zg30Xg&feature=channel&list
Test LinX 0.64, CPUID HM Pro
700
Original http://img-fotki.yandex.ru/get/6519/15673287.c/0_9ebdd_25a8bcf9_orig
This is not all.
Will continue to be integrated:
Changed the video card Gigabyte GeForce GTX 680 + Koolance VID-NX680 (GeForce GTX680)
Scythe Gentle Typhoon changed to 2x 120mm Cooler Master CM EXCALIBUR
Second radiator Koolance Radiator, 1x120mm 11-FPI Copper
Second Koolance PMP-400 High-flow Pump
Link to comment
  • 2 weeks later...
  • 2 weeks later...
HTPC media center upgrade :
Video Card - Asus Radeon HD 7850 changed to ---> Gigabyte Radeon HD 7970 (GV-R797OC-3GD)
modified / changed
Added water block Koolance VID-AR797 (modified / changed)
Koolance Radiator changed to ---> Alphacool NexXxoS XT45 x 2 units
Also modified parts :
Power Supply - Thermaltake TR2 RX changed to ---> OCZ ZT Series 550W
SSD - OCZ Agility 3 60GB changed to ---> INTEL 330 SATA3 SSD 120GB
Final (complete) results :
Next modification assembly Mediatheque (11 x 2TB USB HDD) assembly into a single casing
http://forum.coolermaster.com/viewtopic.php?f=52&t=15881
Link to comment
Little case, great power ( Small box, big power )
„Seeing Cooler Master Elite 120 I realized that this is my home theatre media center ...“
PC Components:
OCZ ZT Series 550W
Intel Core i5-3570K
Intel 330 SATA3 SSD 120GB
Water cooling components:
Koolance RAM-33 X 2
Koolance video block VID-AR797
Radiator Alphacool NexXxoS XT45 x 2 unit
MediaTek components:
WD Elements Desktop 3.5'' 2TB x10 unit
Cooler master cm 4-in-3 device module 3x5.25"->4x3.5" x 4 unit
Psu Enermax Liberty elt400awt
D-link dub-h7 7-port USB x 2 unit
Link to comment
  • 6 months later...
  • Create New...
Important Information
