MikeMaat Posted November 25, 2012 Author Share Posted November 25, 2012 looks very nice indeed, keep up the good work THNX man Link to comment Share on other sites More sharing options...
HACKER354E Posted November 25, 2012 Share Posted November 25, 2012 really a great job! congratulations! Link to comment Share on other sites More sharing options...
MikeMaat Posted November 25, 2012 Author Share Posted November 25, 2012 really a great job! congratulations! THNX still have allot of work to do Link to comment Share on other sites More sharing options...
MikeMaat Posted November 27, 2012 Author Share Posted November 27, 2012 So after a couple days brainstorming about what, how and where to find the wright stuff I finally started with the plumbing part. Here you can see how I made the bends in the allu pipes and cut them on the wright lengths These pipes are for the bottom supports, the upper handles needs still to be shaped en welded with the TIG later one .... For the very first time you can see a familiar shape now Bottom side... The pipes are going to be welded to the bottom with two pipes connecting to each other for extra support. To Be continued ... Link to comment Share on other sites More sharing options...
MikeMaat Posted November 30, 2012 Author Share Posted November 30, 2012 UPDATE !! A BIG disappointment about the welding part of my allu pipes... the guy who was going to help me to TIG the allu pipes says it’s almost impossible to weld them because they are to thin , I have to find another solution now and the time is ticking away . So after that part there was some good news to, I received my water cooling stuff from IT-service.be !! They were so kind to send me the stuff I needed first and will ship the rest separately with no dubble shiping costs so I was able to start on the cooling part ... So here I made two brackets to hold the 2x 420 Phobia rads in the wright angle and place + mounted some Noise Blockers (need 2more do). Tomorrow I hope I found someone or a solution for my pipe part so that the case is ready for sandblasting. Got Somme Bitspower stuff glimmen here to Mounting the Noice Blocker 140mm fans Keep Posted Link to comment Share on other sites More sharing options...
MikeMaat Posted December 2, 2012 Author Share Posted December 2, 2012 Today I mod the mid-plate so it can be used again, it’s a crucial part as it supports the mobo tray, fan holders and the 2x 420mm rads. With support of some heat and a saw I made it useful I that it's about time to remove the protection foil because everything will be sandblasted tomorrow I HOPE !! Some global pictures without the foil ... looks much better Ready for sandblasting !! To be continued...... Link to comment Share on other sites More sharing options...
frozensnail Posted December 2, 2012 Share Posted December 2, 2012 Really like your case mod concept & some top quality work carried out. The radiator mountings & vents look very good Link to comment Share on other sites More sharing options...
MikeMaat Posted December 3, 2012 Author Share Posted December 3, 2012 Really like your case mod concept & some top quality work carried out. The radiator mountings & vents look very good THNX bro, I really hope I am ready this Friday still have to do a lot of work dough Link to comment Share on other sites More sharing options...
Ch2pa Posted December 4, 2012 Share Posted December 4, 2012 I wish you good luck to finish it on time Do you already have an idea of the colour scheme you will use? Link to comment Share on other sites More sharing options...
MikeMaat Posted December 4, 2012 Author Share Posted December 4, 2012 I wish you good luck to finish it on time Do you already have an idea of the colour scheme you will use? THNX going to need it ... I am working hard every day. Color scheme will be all allu style with black/carbon and white LED lightning (kind of ICE cold/light weight theme ) Link to comment Share on other sites More sharing options...
