MonsterMawd Posted February 11, 2013 Share Posted February 11, 2013 We're drawing up the front intake shroud and finalizing the gpu blocks... Andrew will installing Mnpctech's Machined aluminum "Diamond Knurl" pc case feet on his CM II, which are made in HAAS cnc lathe. The base diameter is 1- 3/4" with height of 1" to elevate the case for improved airflow beneath it. They've been painted House of Kolor Kandy Red Link to comment Share on other sites More sharing options...
MonsterMawd Posted February 21, 2013 Share Posted February 21, 2013 Here are screen shots of the custom water blocks and liquid channeled bridge designed by Cheapskate. The blocks will be milled from Copper with Clear acrylic cover and top plate with design inspired by X-Wing fighter wing.These are for Andrew's eVga 680 GTX Classified graphics cards. Link to comment Share on other sites More sharing options...
Pclinde Posted February 21, 2013 Share Posted February 21, 2013 The reservoirs on top, so cool Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 16, 2013 Share Posted March 16, 2013 Thank you pclinde!, We've posted video highlights of the build so far on YouTube Part 1 Part 2 Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 19, 2013 Share Posted March 19, 2013 AC: "Hello, This is Aqua Computer Support. Me: ..."Ah Yes, I'm looking for the Local Chinese Take-Out Listings option on your Aquaero...." AC:.. "Ok, Do you have your remote control handy?, Just scroll down to page 189, It's right under "Tracking Your Lost Dog with Aquaero GPS" Silly, but looking at all of the options makes me feel old, so Andrew will love tinkering with it. Yesterday I made Red Overlay to match the color scheme and installed Andrew's Aquaero into the shroud for the chassis. Aqua Computer's Aquaero product page, http://www.aquacompu.../aquaero-5.html Removing masking tape over window for phoyba RGB light strip CuttingRed Transparent Acrylic Window sheet into overlay for the Aqua Computer Aquaero Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 23, 2013 Share Posted March 23, 2013 6/32 countersink drill bit for the Torx head screws on the Aquaro and installed Phoyba RGB light strip on the side... Link to comment Share on other sites More sharing options...
Andrew_K Posted March 27, 2013 Author Share Posted March 27, 2013 Hey guys! Back again with a little update. Bill has been picking up my slack as I have started my corporate job and have been rather busy. Aquaero Shroud - Leak Testing Waterblocks on the Asus Rampage 4 Motherboard Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 28, 2013 Share Posted March 28, 2013 Need to make some decisions on the front intake design, tonight. Link to comment Share on other sites More sharing options...
MonsterMawd Posted March 31, 2013 Share Posted March 31, 2013 On Friday, Mosquito came into the shop as volunteer camera man :thumb: so we'll be posting another video update of our progress soon. We installed the EK 480 radiator in the ceiling of the Cosmos II, I'll get photos posted soon! and the Alphacool NexXxoS UT60 Full Copper Quad 120mm Radiator will go in the front http://www.frozencpu.com/products/14987 ... iator.html I liked the Copper fasteners they include! Link to comment Share on other sites More sharing options...
MonsterMawd Posted April 2, 2013 Share Posted April 2, 2013 Andrew and I installed the EK 480 radiator with the 120mm Typhoon cooling fans. The EK Reservoir caps, Radiator shroud and Typhoon blades were painted in the same Grey and Red paint, used to paint the exterior of the Cosmos II case. We'll have another update soon! Link to comment Share on other sites More sharing options...
