Jump to content
ZdMods - Project 180
Meelobee
picture.php?albumid=2251&pictureid=31477
Now that I've almost finished Project pÇʇɹÇÊŒuı (Buildlog here: http://forum.highflow.nl/f34/cip-project-p-u-12597/) I've started on a new mod, which I'd like to share with you.
This time no scratch build, but a rebuild of an exisiting case, the Antec P180. Why this case, well simply because I had it sitting around after building Inverted.
Currently the hardware is outdated: Intel Q6600, 4Gb Ram, Radeon 6870. So I'll buy new hardware along the way of the build.
Picture time!
Standard Antec P180 housing
picture.php?albumid=2251&pictureid=31407
Again I'll be using 25x25mm aluminum tubes
picture.php?albumid=2251&pictureid=31408
Cut away parts of the original front to make room for the alu tubes
picture.php?albumid=2251&pictureid=31409
All alu bars in place, 3mm transparant plexi in between
picture.php?albumid=2251&pictureid=31410
Finished the top and bottom with a alu strip
picture.php?albumid=2251&pictureid=31411
Testfit of the front
picture.php?albumid=2251&pictureid=31412
I want to put 2 fans in the front that will draw air from the bottom of the front through the tubes. They won't be able to breathe much, but hopefully enough for what I want to do
Sketchup of the fan cutout in the front
picture.php?albumid=2251&pictureid=31414
This is what it looks like so far, the 2 outer tubes still need to be cut
picture.php?albumid=2251&pictureid=31413
That's it for now...
Link to comment
I've done some more work on the case:
First I've finished the front, the fans are now countersunk into the tubes
picture.php?albumid=2251&pictureid=31466
There were some damaged area's on the plexi which I filed down, before:
picture.php?albumid=2251&pictureid=31467
After:
picture.php?albumid=2251&pictureid=31468
Fans fitted
picture.php?albumid=2251&pictureid=31469
picture.php?albumid=2251&pictureid=31470
Front on the case
picture.php?albumid=2251&pictureid=31471
I've bought some pieces of alu sheet to replace the front, back and midplate of the case.
Took the case apart, the white sheets on the left are the new alu parts
picture.php?albumid=2251&pictureid=31472
After cutting the front and back there wasn't much of the original material left
picture.php?albumid=2251&pictureid=31473
Made the front sheet to size
picture.php?albumid=2251&pictureid=31474
And bolted it all together again
picture.php?albumid=2251&pictureid=31475
picture.php?albumid=2251&pictureid=31476
Link to comment
picture.php?albumid=2251&pictureid=31415
Had some time to work on the case this weekend, first I've put the original I/O panel into the midplate.
picture.php?albumid=2251&pictureid=31528
picture.php?albumid=2251&pictureid=31529
Then I've cut 2 bars to replace the top piece of the case. To still be able to slide in the sidepanels (the panels have small hooks) I had to cut 3 rectangular holes in the side of each bar
picture.php?albumid=2251&pictureid=31530
The 2 top bars sit on L shaped pieces attached to the front and back of the case
picture.php?albumid=2251&pictureid=31531
picture.php?albumid=2251&pictureid=31532
picture.php?albumid=2251&pictureid=31533
picture.php?albumid=2251&pictureid=31534
With the sidepanels on it's all flush and straight :)
picture.php?albumid=2251&pictureid=31535
picture.php?albumid=2251&pictureid=31536
I've polished the strips on the top and bottom of the front with Commandant #4 after sanding them to P800
picture.php?albumid=2251&pictureid=31537
Link to comment
During the week I received a package from Coolermaster, they decided to sponsor my project and send me a very nice Silent pro M2 1000w psu and 7 Excalibur 120mm fans.
picture.php?albumid=2251&pictureid=31677
picture.php?albumid=2251&pictureid=31678
picture.php?albumid=2251&pictureid=31679
picture.php?albumid=2251&pictureid=31680
picture.php?albumid=2251&pictureid=31681
picture.php?albumid=2251&pictureid=31682
picture.php?albumid=2251&pictureid=31683
Big thanks to Marco from Coolermaster Benelux for making this happen :cheers:
And I also have a small update:
Did a bit more work on the top of the case. I've put plexi and aluminum corners onto the bars that hold the sidepanels.
This way each side of the top looks like it's made out of two bars with plexi in between. And I still have room to put a 360 radiator right under the top of the case 8)
picture.php?albumid=2251&pictureid=31684
picture.php?albumid=2251&pictureid=31685
And I've used a small piece of alu tube to make the backside of the top
picture.php?albumid=2251&pictureid=31686
Link to comment
  • Create New...
Important Information
