Jim Weist Posted August 5, 2013 Share Posted August 5, 2013 Hey there fellow Cooler Master modders! I have been working on finishing my first mod. When I first started I didn't think to correctly photo for a work log. So for this build its starting at the beginning of the water loop I'm installing. I have my build on a couple other forums, bit-tech and OCN, and I figured I would put it here because its a Cooler Master case and I changed it up quite a bit. Ill start my photos from the current set up and photos from the modding I did over the last week, putting on the finish trim pieces, before I install the loop in about 2 weeks. The reservoir in the photo was sent back because it had too much of a pink color to it and didn't match my build. Here are the components list and some photos.My components are as follows:*CPU: Intel 3930k 6-Core LGA 2011*CPU Cooler: Corsair H80i*MB: Asus Rampage IV Exreme*RAM: 8 Gb Corsair @ 1600Mhz*GPU: 2x Evga 480 GTX in SLI*PSU: Thermaltake Toughpower 1050W*SSD: Samsung 840 Pro 256 Gb*HDD: WD 10000 rpm Raptor 140 Gb*OPTICAL: LG Bluray Burner*Case: Cooler Master HAF 932 *Modified Link to comment Share on other sites More sharing options...
Jim Weist Posted January 12, 2014 Author Share Posted January 12, 2014 This photo was taken before a week ago when I made the rim This is a view with the custom side panel window I made. Its from before I installed the trim and thumb screws as well.Well i think I brought you up to speed on my HAF 932, Ill update here soon as I install my water loop and get everything in order. Thanks for checking out my rig I hope you like it! If you do be on the look out, Im going to be starting a N200 or HAF XB micro ATX mod after this is complete, I already have quite a bit of ideas planned out and I might even start the case work before this water loop is done because I hate not having a project to work on while waiting for parts.=D Modding is my new found passion for sure. Link to comment Share on other sites More sharing options...
Jim Weist Posted January 12, 2014 Author Share Posted January 12, 2014 Here is the final update of the build where I added the actual water loop to it. It will be a 2 part update and then I have a final photo set of the build. Link to comment Share on other sites More sharing options...
Jim Weist Posted January 12, 2014 Author Share Posted January 12, 2014 Sorry for the larger size, I was a noob when I uploaded these and didn't change the resolution. Link to comment Share on other sites More sharing options...
Jim Weist Posted January 12, 2014 Author Share Posted January 12, 2014 Here is the final photo set I took of the HAF932 I named Kubrick. Its not bad for my first noobie adventure into PC modding.! That's it for this one. Check out the next project I did called "Grey Matter"! I have made vast improvements in my skills with tools, in my photography, and in my work log quality! Here is a link for the 2013 Cooler Master Case Mod Competition worklog. The one in my signature is for Bit-tech.net. GREY MATTER Well Enjoy and take care! Link to comment Share on other sites More sharing options...
z999z3mystorys Posted January 13, 2014 Share Posted January 13, 2014 I find that very impressive, I have a hobby with computers, but that is a passion imo. great build! Link to comment Share on other sites More sharing options...
Jim Weist Posted January 14, 2014 Author Share Posted January 14, 2014 I find that very impressive, I have a hobby with computers, but that is a passion imo. great build! Thanks bud! I appreciate the feed back, this build kinda got lost a bit, I made I think 3 work logs but there were pretty shotty because it was my first time. I did a lot of research on the whole process of modding and work logs and got up to speed when I made my Grey Matter project. I am glad someone came back and recognized this project because for me this is where it all started. I think one day I will come back and resurrect this build with my new tools and skills I have gained. Link to comment Share on other sites More sharing options...
