Jump to content
Raz3r D3sk
Peter Brands
  • 4 months later...
  • Replies 28
  • Created
  • Last Reply
And black.
Small amount of glue on the corners.
I'm very happy with the end result.
And ... I can always re-use them ... the acrylic is easy to replace for a different design/color.
Thanks a lot Scott, Ivo and Sander, it was an awesome 'little' project!
Link to comment
Thanks guys!
Time to get back on this project!
Been busy the last few weeks with some other things that needed to happen first :)
First ordered some more Q-blocks
Think these will give a cool effect too.
Something I did which took me a few full days.
Cleaned up and re-organised the complete attic. :)
And another thing I did..
Probably the cheapest case I ever made :)
Desk for the 'clean' work.
Also received something really nice from ASUS Benelux.
Screams to be modificated ;)
Such a pleasure to work in a clean spot ;)
On to the next updates!
Link to comment
Thanks guys! :thumb:
Decided to only use some handtools and a dremel this time :)
First wreck it.
And measuring the acrylic.
First drilled the holes then used the fretsaw.
You can easily drill holes near the edges with a dremel on high speed by the way without breaking it.
And sanded the edges.
More measuring.
Always a lovely moment when you can peel off the protection layer :P
Used transparent glue and left it to dry for a night.
Then I found out I didn't have long M2 bolts after all ..
So removed the standoff's and drilled all holes in PCB and covers with 3.2mm.
Plenty of M3 here :)
30 nuts later.
And with some LEDS on.
With his little sisters.
Link to comment
Thanks guys!
I'm still alive ;)
Months ago I got the idea to have a PS4 on the right side, cooled with custom made waterblocks.
However after months of doubt I have decided not to do this cause of the time and finances involved for this (MARSII block.. pfff )
Last weekend I took a few hours to see how I will continue .. and .. I'm totally back :)
Also will use the pumps and reservoirs separate instead of the combo's.
And .. going to do 2 separate loops with each 2 pumps, however with the use of 4 valves I want to be able to switch to one huge loop with 4 pumps and 4 radiators.
So .. another update.
Used rubber again on top of the acrylic edge to hide the green top side and isolate the desk inside.
Also 2 extra grills from ModWithMe which I will use on the inside of the desk.
The Raz3rator.
Finally I can mount all 4 Admirals
Ook kan ik eindelijk alle andere radiatoren monteren.
Number 1
Two.
Removing sticker from the other fans.
Quite some bolts.
Number 3 done
Something I ordered months ago through Kickstarter.
Ambilight :)
More about that later.
Also 2 long LED strips inside, nice effect when opening it :)
And the last one.
Number 4 .. done.
This photo was made just after I decided to drop the PS4 idea and I was measuring it all.
First make the reservoir covers a little more shiny .. not too much, don't want to see all the leds in detail.
Sawn off all reservoir clamps.
And another try :)
You will lose the skin on your fingers ... but I love it! :)
Testing how it will look with a Bitspower LED RAM MOD underneath.
Means it will have the same 'heartbeat' effect as the Razer mice. (See video!)
Will be a lot of measuring :D
This is how the should work, and yep I often use paint for these kind of things :P
Things could still change but personally I already like it.
And a short video of how it's standing now.
Link to comment
Really glad you're helping out Justin :D
Another update!
Back to the Benchtable.
It still needs some extra holes for tubing and wires.
Also on top
Quick disconnects.
And tubing on the inside.
Completely forgot there were still red buttons in the desk :)
So ordered 4 new green ones from Highflow.
Also bought a print from a forum user there, will be able to use momentary switches to switch all lighting on and off with led notification.
So also replaced those
Extra hole for a fillport in the 'firewall'.
Also drilled the 2 quickdisconnects in the desk, tight fit.
What a mess ..
Here is where I noticed I was going to run short on fittings.
Glad Vincent from Bitspower was able to help me out.
Measuring.
And another small step further :)
Best thing there is .. finding this on your desk after a long day.
Ultraunpackspeed
Link to comment
Bitspower Enhance Multilinks. Love them ..  compression fittings for Acrylic.
Already made one for Cross desk but need more power.
With this all the fans, lighting and pumps will always run, no matter if there's one of the pc's is running or both.
Also connected all 14 fans to the Lamptron controllers.
And some sleeving
Not going to sleev the cables out of sight .. just too much lol
The top Lamptron is to switch Ledstrip.
Bottom one to control the Bitspower RAM MODS which will be under the GPU's and reservoirs.
More cables.
Cables gone..
Mounted the controllers and used some glue on the back to hide the bleeding light
Off course .. a Silvercoil.
Between the GPU's
Also changed some in the middle
More coming soon!
Link to comment
Now that I'm back up to date on the community forum .. Here we go :)
At the moment very busy at work, still hoping to finish it this summer :)
So .. 'small' update again.
First a replacement for the slot bracket.
And found a way to still use the HDD brackets :)
A nice bed for the SSD's.
Also bought some more acrylic fittings from another modder.
Measured, drilled and filed all holes for the 'bridge'.
Also the connections for the HDD's.
Built in the fan controllers and connected them to the 14 fans.
Used 3M Dinoc to hide the red Sata slots.
And started with the loop from the benchtable. Added a small reservoir on top.
So .. a little further.
Here's something I've been walking around with for a long time.
A logo for the legs and top panel.
Then you have an idea but .. how to continue?
Glad there were 2 awesome guys I got to know from a previous project who wanted to help me out.
<3 Parvum systems CNC :)
Thanks a lot Justin and specially Shaun for making my figment reality! (Sorry mate :D )
Link to comment
  • 2 weeks later...
Had to spend a few hours on the hot attic :)
The acrylic borders are now completely enlightened. (see video at the end)
Also started with the loop on the left side.
The back will still be quite some work.
But this loop will probably remain like this.
I love chaos :)
Still can't wait to fill it up.
Video of the RGB controller with UV leds.
Link to comment
  • Create New...
Important Information
