Jump to content
Raz3r D3sk
Peter Brands
And further on the loop :)
Also I need a paper next to it for the flowdirection.
3 hours and 1mm of skin later.
Here the funpackage I got from Razer almost a year ago :)
Off course had to unpack it.
Check these lovely babies :)
Another long waited package arrived.
Because I didn't count on it anymore I had to change plans.
So slept a night on it.
Think the contrast is better like this..
And ... the pumpstation.
With this I can make one big loop for both pc's with 4 rads and 4 pumps.
Or one loop per system with each 2 pumps and 2 rads.
Backside finished too.
Also added 2 green LED strips on the bottom to be able to see something there.
I will be able to switch it off or dim it with the Lamptron controller.
Ready to fill :)
I prefer filling with clear liquid and adding color later.
Because .....
I had several leaks, this while I tested everything in front.
Few hours later 1 radiator seemed to leak.
Temporary solved it this way.
But then finally .... loop up and running!
Mau approves :)
Next update soon!
Link to comment
  • Replies 28
  • Created
  • Last Reply
  • 3 weeks later...
  • 3 weeks later...
  • 2 weeks later...
  • 7 months later...
  • Create New...
Important Information
