L4mka Posted October 11, 2013 Share Posted October 11, 2013 Hi, I'm new here, so sorry for some mistakes and my english My PC was very noisy when I played games, so I was thinking more and more about creating watercooling rig, but it was rather dream. Few months ago I need a new desk and in the same time I saw L3P's projects (L3p desk, Cross by Redharbinger).. So I decided to make my own desk including computer with water cooling.SPONSORSWith PSU V850 and 4x JetFlo 120 red fan.With EK-HD fittings and angle adapters.GTX770DC2OCWith Alphacool radiators and few special fittings.Thank a lot to sponsors. I can't finis this project without these parts.I spent hours figuring out how to do it all. Next days I was making some sketches in Google Sketchup and after that and then I finally drew everything in AutoCAD. Link to comment Share on other sites More sharing options...
L4mka Posted October 13, 2013 Author Share Posted October 13, 2013 FIRST UPDATE After laser cutting and bending the "main" part of desk, I bring it home and test it little bit Everything started on this nice laser cutter And continues on this powder coater Finally at home! Testing some old MB and fans, everything fits as I wanted. After that I must do slot for MB. I used back part of old Eurocase.. :idea: I cuted off all unnecessary parts then I resurfaced it. And test it into lasercutted part. Link to comment Share on other sites More sharing options...
L4mka Posted October 21, 2013 Author Share Posted October 21, 2013 Hi, I am pleased to introduce a new sponsor - Aquatuning. They joined the project with beautiful radiators and special fittings. Thanks a lot to this company! Link to comment Share on other sites More sharing options...
L4mka Posted October 23, 2013 Author Share Posted October 23, 2013 UPDATE Making the HDD holder, I try so much options and this is the best imo. Painted with RAL9005 and test in in desk I also paint the MB slot I started sleeving PCIE and 24PIN. 6pin PCIE 24PIN + waiting for black connector Link to comment Share on other sites More sharing options...
L4mka Posted October 27, 2013 Author Share Posted October 27, 2013 UPDATE Last week I was very busy, because I was making the desk from wood. I am not so good in wooden works, so I made the desk with my friend in his factory. That is him! Wooden part of desk is made from material Egger1137ST (oak). Afterk co-op working with me friend i bring the desk home. COOLERMASTER SPONSORED PARTS Thanks a lot Cooler Master for their help and for sending me PSU 850V and 4x JetFlo 120 Red Fan. Enjoy photos of CoolerMaster quality products! Link to comment Share on other sites More sharing options...
L4mka Posted October 29, 2013 Author Share Posted October 29, 2013 UPDATE I am here with next update. I added to desk switches for ledstrips, on/off button and fan regulators. There are 3 photos of empty desk with switches. In this photo are mentioned switches. From left: on/off button, on/off button for left fans, on/off for led strip, on/off red strip, on/off strip on back of monitor (not decided which color). These are 90mm cutted threads for holding the desk with reserviors. They will hold this desk with reserviors. Arrived package from Aquatuning.de Thank a lot to this company for radiators and few extension fittings! Started to install radiators. UT30 Full Copper 360 on left side. And install CoolerMaster fans. UT60 Full Copper 360 on right side. Install Scytche Gentle Typhoon fans. And the doted aluminium cover Link to comment Share on other sites More sharing options...
L4mka Posted November 10, 2013 Author Share Posted November 10, 2013 UPDATE I did not have so much time last 2 weeks, so here is new update. At first I done electrical wiring to FANs and led strips. And try red and blue lighting. I started to completing steel parts. Desk for reserviors and steel bulkhead (wall) And with closed top. Made holes for threaded rod to hold desk for reserviors. Looks good imo. SPONSOR UPDATE Arrived awesome package from ASUS Czech Republic GTX770DC2OC Installed Alphacool D5 pump on place. FIRST TUBE Tubing with John Guest push-in fittings, working with them beautifully. And made drain port. Connect the first reservior to the loop. And the second reservior connected. View on tubed part with the wall. Link to comment Share on other sites More sharing options...
L4mka Posted November 19, 2013 Author Share Posted November 19, 2013 SMALL UPDATE Hi, I am very busy last weeks so I post only small update Arrived blocks and fittings from EKWB. So I installed them. Small army of EKWB Fitiings Thank you so much EKWB for them! EK-RAM Monarch X4 - Acetal+Nickel CSQ + EKWB Fittings Installed EK Water Blocks EK-Supremacy - Nickel Acetal + EK-HD adapters Started with tubing. 10/12 Acrylic pipes and EKWB Fittings - working with them is beautiful! Link to comment Share on other sites More sharing options...
L4mka Posted November 28, 2013 Author Share Posted November 28, 2013 AquaTuning UPDATE Hi, today only small update about next sponsored package from Aquatuning.de. In this package is second D5pump, tubing and few fittings and nice present - AquaTuning T-shirt!! Thanks a lot for this help! D5+TOP, tubing and fittings all Alphacool. Very nice T-shirt! I really like it Stay tuned, on weekend will be bigger update with GPU Link to comment Share on other sites More sharing options...
L4mka Posted December 2, 2013 Author Share Posted December 2, 2013 UPDATE Hi, at the weekend I installed block on GPU and fit it to the mobo and connect some more tubing Tomorrow I will install the second pump into desk and will do some flow tests. Asus GTX770DC2OC and EKWB block Naked 770 And with EKWB block Installed GPU in MB and connected with tube to RAM block More tubes connected. From GPU will be connected into ST30 360mm radiator. Link to comment Share on other sites More sharing options...
