Jump to content
**Scratch Build*** Hellboy ////Completed\\\\(21/11/56 )
Hello everyone. Today I will present my own projects.
But first I would like to inform you that I was not good at English.
Instead, use Google to help sorry if any mistakes in communication.
To do about it. This project began with a theme first. I have a hero in my heart that is Hellboy. Then replicated by a computer program.
It then started to cut the model first. It may have to be adjusted proportionally in the future. To cut to precision CNC machine I have at work.
When finished, cut it to the process of assembling it.
When completed. I was asked to cut the tiles to radiator it.
Okay, it's pretty perfect as possible ^ ^
Then brought together. To check the position of the various devices.
Try out a site compared with THEBOX360 [iTX].
Ladies and gentlemen, it's time that we start to build a real case of it. ^ ^.
The material used is plaswood sheet strength close to the acrylic. Lightweight flexibility.
When the cut was finished and polished to a beautiful To prepare to paint.
I chose black and red to match the theme.
Red and black split apart. To make it easier to work.
Anchors and bolts.
Masks with screw worm.
Then came together.
It's time to move to a new home.
From the radiator first.
Followed by tank and Fill Port.
Pipe installation.
Install a second radiator.
Relax your eyes by looking pretty..
Look back together. This step is the installation of hardware.
Starting from the motherboard first.
PSU
Display
install pipe again.
Next, check the water leak and fill colors. (Vedio)
Install and test the light.
The side doing well.
Image processing tasks 80%.
Link to comment
See the tricks of this case.
First., It can place up to five forms such as the Standard. Vertical line of high landscape., And inverted.
Preview for understanding.
This is real. However, due to the cooling devices. Not so laid back side.
Step two is technical. Mask can take many forms. To reduce the monotony. You can create multiple forms in a single case
Although the side wall can create works as well.
If I put in bold acrylic crystal.
If you like to put 2 and 2 at all.
Red light will reflect enough light to make the flame more info.
Link to comment
  • 3 weeks later...
  • 2 weeks later...
make window acrylic broken
make new disign
When everything is perfect. Was due to start again with a new review ^ ^
You can view the process as a sequence of images.
When everything is ready, it started to engage them.
Link to comment
  • 8 months later...
  • Create New...
Important Information
