Jump to content
[Scratchbuild] µBox by Ch2pa - CANCELED
Ch2pa
Ninth Update:
I cut two aluminum "L" shaped profiles, and drilled them:
Then I fixed them on the front part of the stucture:
These profiles will be used for the fixation of the CoolerMaster Seidon 240M radiator.
I wait for the radiator before drilling its fixations holes because I have a doubt on its dimensions.
I started the covers for the front faces. They will hide the DVD/Blu-Ray reader and the front panel.
For this I used a cutout that I spared:
As this cutout comes from the same plank and position in this plank as the side, the veining of wood are similar:
And my goal will be to keep this veining continuity
I cut this piece with a hacksaw (which has smaller teeth than a handsaw):
Then I did the finishing with a belt sander and sand paper. The result is quit what I expected:
The only thing left for this cover is to do the hole for the eject button.
Other side, same process.
I used a cutout for the front panel cover:
Roughly hewn with hacksaw, belt sander and sandpaper:
Prior to the holes in the cover, I had to finish the fixation of the front panel.
For this fixation, I used a small sheet of aluminum:
That I cut and fold:
I used the existing fixation holes to screw the front panel on its support.
For the fixation of the front panel support on the wood, I cut a cover in aluminum:
Two screws tighten this cover on the wood, two other screws tighten the front panel on this cover:
Last piece of the front, I cut in a small block of aluminum:
To do:
The power on Button:
Now that the front panel is completed and fixed, I started to do the holes in its cover:
Not yet finished, only the audio and USB ports for now:
Stay tuned
Link to comment
  • Create New...
Important Information
