Jim Weist Posted July 29, 2014 Author Share Posted July 29, 2014 They came out super clean! Next up to the plate was the Apogee XK Cpu waterblock. I drilled out the plugs for the mod plate and tapped them to M3. I dont recommend this if you aren't confident in yourself, one slip and you pop right into the center of the block and its ruined! Luckily I made it out alive =D Then I broke it down for paint. I also sleeved the power cable for the led boards with the Mod/Smart Maxcord. I was happy with the turn out! I'm going to use the CNC to mill a cut out in the top panel and paint it copper so white light shines through. Next up is the GPU block! First was the tear down process. These are some hardcore water blocks, not the standard 2 layer block there is about 5 or 6 haha. Link to comment Share on other sites More sharing options...
Jim Weist Posted July 29, 2014 Author Share Posted July 29, 2014 Okay after that process it was time for paint! Here I drilled out for M3 screws again from the little philips that come with it, then counter sunk this plate. Back to paint! Link to comment Share on other sites More sharing options...
Jim Weist Posted July 29, 2014 Author Share Posted July 29, 2014 Here is another screw replacement for m3 for the Gpu logo plate. =D Now back to paint haha! Last up for paint was the back plate. After everything was painted I reassembled it and holy crap! They don't even look like the same waterblocks!!! I also switched out the black alloy screws for stainless steel screws, I think they matched better. I Can't wait to get these on some 780's and in the build! Link to comment Share on other sites More sharing options...
Jim Weist Posted July 29, 2014 Author Share Posted July 29, 2014 Hard to top those blocks but I want to show you the painted reservoir really quick! I got the bottom one in primer, the top one is complete and ready for install though and thats what I want to show. The reason I painted after glueing it on is that the weld-on glue is very strong and would smear the paint right off. It was a real paint to mask off inside the pocket the trim created but well worth it in the end! Well that wraps up another forum update don't forget you can catch daily updates and CNC work at my Facebook page Clockwerk Case Mods! Thanks for watching!! Link to comment Share on other sites More sharing options...
FannBlade Posted July 29, 2014 Share Posted July 29, 2014 Very nice attention to detail! That res is sick....you do amazing work,can't wait to see you whipping parts out on the CNC!! Link to comment Share on other sites More sharing options...
Jim Weist Posted July 30, 2014 Author Share Posted July 30, 2014 Very nice attention to detail! That res is sick....you do amazing work,can't wait to see you whipping parts out on the CNC!! Thanks Fann! Oh man I am working with the CNC every day! I cant wait to become proficient with it! Link to comment Share on other sites More sharing options...
TekLord Posted July 30, 2014 Share Posted July 30, 2014 Looking great man. Link to comment Share on other sites More sharing options...
Jim Weist Posted July 30, 2014 Author Share Posted July 30, 2014 Looking great man. thanks buddy! I really like your final photos on demon speeding man good job! Link to comment Share on other sites More sharing options...
Jim Weist Posted August 19, 2014 Author Share Posted August 19, 2014 Hey everyone!! Sorry for the delay in updates, even on my Facebook page its been slow the last couple weeks, I had a lot going on, I had client work, I also had to finish the CNC and get it tweaked and in working order. Now my workload has cleared, I got a new camera and I am back in action on this project! I also decided to start doing video logs for my builds! I recently got a Canon Rebel T5i and it takes amazing photos and videos, so I figured why not, more skills to add on my resume haha. I will start posting my forum updates as a mix of video and photo. Ill be taking 15 photos and embedding a youtube video. Im going to run with this and see how the response is for now. Anyhow, I hope everyone appreciates the time I took to film and edit the videos, I have a lot to learn yet, but I don't think I did all that bad for the first go at it. I am going to do more audio commentary and less invideo explanation as it tends to drag on the clock. Anyways on with the update! First and foremost as always, thanks to these awesome sponsors! you guys really exceeded my expectations and are helping to make an awesome build come to life, this would of been extremely difficult without your support! I got a few more items in from Mod/Smart and Primochill! Some more Maxcord paracord, and heatshrink, and a jig for bending rigid plastic tubing! This jig is insanely impressive! Way larger that I imagined it, and should work wonders here shortly when I start installing tubing! As I said before I had been super busy over the last few weeks, but I managed to get my bottom case reservoir finished, make a window to my PSU, trim my IO panel, and make a LED lit solid state panel. I used my CNC to cut out these little rhombus shapes, and painted them copper, to give a blade effect on the IO panel. when the MB is modded white and copper it will all blend together very well I think! I also slapped some paint on the bottom reservoir and it ended up just as nice as the top res, they should look pretty sweet paired up in this rig! I got a new bottom case mesh also from a friend Shane on facebook, and fixed my bottom bezel up. The last thing I did was get the SSD mounting panel made. I just have to cut out my Corsair sails on the CNC, paint them copper, and glue them on the SSDs. Thats all for the photos, here is my first video update! I hope you liked the update! Cheers guys see ya soon! Link to comment Share on other sites More sharing options...
Jim Weist Posted October 10, 2014 Author Share Posted October 10, 2014 Hey guys back with another update, I have about 15 photos and another video update. After this update I will have a few shorter videos rather than one longer video and they will be in a play list, that way I will have more videos on youtube more frequently to view, and also I can group them into playlists. Also i would like to thank everyone who voted for Cyprus29 for Mod of the Month in July 2014, I appreciate it a lot, Im glad to see people noticed the hours and hours of work I have put in this project! Cheers to you guys! In this update I finished the corsair logos for my solid state drives, I made a new rear panel for the lower case, I also made and enclosure for my Swiftech MCP35x2 pump, and lastly I didnt photo it but I made a new IO panel with blades that fit inside the case First off thanks to my sponsors, with out you guys this project wouldn't be nearly as awesome! Okay first think is the new IO panel here is a couple shots Here is the new rear panel with the MNPCtech billet fan ring. Copper modded of course. I also added a different mesh, I used the larger holed MNPCtech mesh instead of the small hole version it comes with. Now the juicy stuff! Here is the Corsair SSDs I finished by adding acrylic cutouts of the sail logo. Last my favorite part of the update and maybe my favorite thing in the build so far, the custom enclosure for the Swiftech MCP35x2 pump. I wanted to do something I have never seen and a complete enclosure for the pump sounded like a great idea! Here are a few shots of the bottom case now as it sits. Now here is the video footage of the build process. As I said before the next update will either have a few videos embedded in or a video playlist embedded in. I want to try to get the videos at a 15 minute maximum. fgS9fw43nGs Well thats it for now, as I said please bare with me as I get adjusted to this video thing, I think its an awesome way to bring modding to you guys and I just need to get better at doing it, I pick up on things pretty quickly so it will get a lot smoother sooner than later! Until next time take care and mod on! Link to comment Share on other sites More sharing options...
