Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Waterblock fitted, and now im going to see if i can keep the Matrix LED indicator as its very useful in letting me know that the crossfire is working and how hard, Looks nice also My black perspex has arrived so i can start having a play, was wanting to use it for the triple RAD grills and possibly the Matrix LED. Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Finally my 12v push on/off switches have arrived Will be used for the UV/LED lighting. Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Stared working on the pump & res base, a total remake but just a bit bigger than the 1st one i made and now has a hole for the pump instead of hiding the pump in the bottom compartment the fan was just there to hold the base up as i fitted the carbon, hole will be housing the pump Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Switches to control the UV/LED lighting New switches fitted in working, 1st for the LED master on/off, 2nd and 3rd are for the UV lighting on/off Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Ordered myself some black tights ( wife got a bit suspicious when they arrived lol) and some thin light wood to make a fan hole cover, this will go on the base of the desk near the PSU, and will eliminate the need for 120mm fan dust covers Here i have covered a old triple RAD fan extension, this will hold the 3 intake fans on the uper right side Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 old triple RAD fan cover cut down to a double for the lower air hole near PSU Wrapped ready for cutting Another fan cover wrapped and cut Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 RADs and pump in place along with the new pump carbon wrap cover (RES base) Needed to extend most the fan wires, forgot to take a pic The converted triple RAD fan holder fitted to replace the wood that was there on the test build redone the sides with new wrap, the triple RAD shown here was not in the test build, Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 Took some doing, but Finally worked out a way to keep the matrix LED's 14/04/2014 - Just noticed i forgot to add the fan photos, so here they are CM Jet Flows - plane black no LED's Nice to have 2 speed controllers included with the fan, 1200rpm & 1600rpm forgive the sawdust didn't look that bad without the camera flash lol removable rubber ends!, if i had not already cut the wood i would have removed the four fan ends and cut circles not squares as the fans are about the same thickness as the wood and would have looked great. Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 made some blocks to raise the RES a inch higher, i might get a clear pump top in the future and light it???? The tubing covering the GPU bridge can be removed, and atm its no longer on, cant decide if i like it on or off Link to comment Share on other sites More sharing options...
Deblow Posted March 28, 2014 Author Share Posted March 28, 2014 New wrap added to the front, new switches and new fan controller also partially covered the blu-ray drive under the blu-ray is my drink holder (converted DVD drive) the bottom bay holds my main OS SSD drive Link to comment Share on other sites More sharing options...
