Jump to content
Hello. This is Project Penn Carbon. A college themed build for me and my friend. I've had the case for over 8 years. 6 years it was in use and ran strong prior when I even had computer knowledge. After the rig died, I moved onto a HAF 922 which then was upgraded for a Air Carbide 540. I've wanted to mod this case for years and now Its finally happening.
Here are some original pictures from Cooler Master's website.
13_95f7c104876ed2448f83bf70e90ace07_1370
13_aad783fb94d83c87d42c6b1f16d1405e_1370
13_156877cb044041e3f3ea8e7c9b163041_1370
Update 5/3/2014
The case came back from the powder coating place. Heres some pictures of the case with the powder coat and some temp hardware inside.
10170779_10201742360913363_5323412196213
Wish I could remesh the front but don't quite know where I could locate some flexible mesh. I would love to just mess with a new elite 340 panel but its hard to find without buying a whole new case.
10325348_10201742361233371_6062047777916
Little out of focus but it shows how nice the powder coat actually looks. Hope we've grabbed your attention now ;)
10254007_10201742363153419_8996386291579
Motherboard tray and interior. Top is not done because top will be modded to fit a fan so the power supply can draw fresh air from outside rather be turned upside down and drown in the processor and GPU heat that is constinly rising.
10171240_10201742362233396_5299991591720
Nice flash shot of the case. The color really comes out in the light.
10154096_10201742361713383_6278365471181
Shot from the I/O cutout. This really shows how well the color can be manipulated via differnt lighting.
10342828_10201742363673432_7619117244455
10154546_10201742358553304_9020034784481
Disregaurd the hardware... Hopfully we get new hardware, espically new case fans because we'd love that! ;)hint hint cooler master
1526387_10201742359073317_58041739157442
Things that still need done
- 120mm cut out for the back fan
- dual 120m cut outs for 2 front fans to be mounted in the front of the case.
- Fan cutout for power supply to face up to draw fresh air for better cooling.
- Shroud cutout
- Carbon wrap shroud
- Window cutout on side panel
- Acrylic window cutout
Hardware still needed
- 3/4 hole saw
- More acrylic sheets
- More carbon vinyl
- Anodized thumb screws (Blue or Black)
- Casefans, Suggestions are being taken.
- NZXT CB-LED10-WT Sleeved LED Kit
- Hard drive, thinking 500G. It has to be a 2.5in form factor
Link to comment
  • Create New...
Important Information
