IMCustoms Posted February 12, 2015 Author Share Posted February 12, 2015 Sorry guys for no updates for a while.. I was quite a bit sick.. Got some stomach flu and than a regular flu.. Shitty stuff all around.. But I'm better now, and let's get this ball rolling again! Update: Bitspower was finally sent me (I hope) the right fittings and not some prototypes again And also, I will do a review of one of their upcoming products, and I hope many more later Everything is remeasured and prepared for some heavy wood and wall work, and I'll start chopping in the next few days I've also finished my final EK motherboard block video, which will be rendering overnight and uploaded tomorrow and here is a shot of that And that's all for now, cya a bit later when this video gets uploaded Link to comment Share on other sites More sharing options...
IMCustoms Posted February 12, 2015 Author Share Posted February 12, 2015 And here it is, Unboxing and Mounting tutorial of EK-FB GA G1.Sniper 5 - Acetal+Nickel Link to comment Share on other sites More sharing options...
IMCustoms Posted February 13, 2015 Author Share Posted February 13, 2015 Some of you on the forums and some sponsors have asked did I do some "actual" work, so today I took some time to prebuild the system on the floor, just so you all can see the layout and to test-fit everything, and to check out my computer measurements with the things I already built Also I've done some tube bending, but I'm waiting for BP fittings to arrive to finish that.. And you can also see some types of screws, nuts, bolts and washers that I'll use to mount this beast to the wall Link to comment Share on other sites More sharing options...
IMCustoms Posted February 16, 2015 Author Share Posted February 16, 2015 It has grown legs #scared Some stuff will be fabricated tonight Link to comment Share on other sites More sharing options...
IMCustoms Posted February 17, 2015 Author Share Posted February 17, 2015 So, today I made a couple of things.. Firstly I drilled holes in "main board" (that's how I'll call it from now on) for motherboard standoffs and 4 SSD's.. For now I have only 2 SSD's, but I'll contact a couple of manufactures to see if they can contribute for 2 more, or 4 new ones Also, SSD's will be easily removable, cause I'll pre-attach these bolts and plexiglass (later about that) on SSD, and then just slide it into these holes, and bolt heads will get stuck and it won't be able to fall out, but just as a precaution I will probably put some velcro or double sided tape too. Then I test fitted everything and made this plexi cutout for cable extenders, and you'll see later how I'll implement them Link to comment Share on other sites More sharing options...
IMCustoms Posted February 17, 2015 Author Share Posted February 17, 2015 I did some more work today More drilling, jigsawing, sanding and voila! PSU bracket and holes for 2 fans are compete Link to comment Share on other sites More sharing options...
IMCustoms Posted February 22, 2015 Author Share Posted February 22, 2015 Hey guys, new update ! The last part of Bitspower parts has finally arrived and those problematic fittings are much better now.. So in a last couple of days, I took the time to test them, decide where and how everything will fit and test-fit everything, and bagged and tagged it Also, I almost finished marking everything up for cutting and I only need to design 1 more plexi panel and finalize the design of reservoirs.. And I hit the problem with those 3 big curved plexi covers, cause apparently no-one in my country can curve plexiglass in that radius, but only in strait 90 degree angle.. blahh.. So yeah, I will probably have to change my design a bit, but I don't think you will be disappointed with what I came up with And here are a few shots Link to comment Share on other sites More sharing options...
IMCustoms Posted February 24, 2015 Author Share Posted February 24, 2015 Sanded 2 plastic tubes, so I can bend my tubes around them... And I think I'm on the right track so far.. What do you think?? Link to comment Share on other sites More sharing options...
IMCustoms Posted February 24, 2015 Author Share Posted February 24, 2015 OMG IT'S DOUBLE RAINBOW WOOO ! Ahh... It's just double bent hard tubing.. No big deal, right? *sarcastic simle* Link to comment Share on other sites More sharing options...
IMCustoms Posted February 25, 2015 Author Share Posted February 25, 2015 Some more (for me) first time stuff needed to be tested And here is the result: Link to comment Share on other sites More sharing options...
