Jump to content
'Calibre' by Sphinx Modding
Sphinx818
Hi all! This is a mod which is special to me as it represents the sheer awe of war, both the good and bad, this is a theme that I have tried to implement within my mod. Enjoy!
This is how I got the ammo box (Yes this is a real wooden ammo box from the 1980's!)
With this mod, I wanted it to be portable for all of the great LAN events, or to have epic gaming nights at home:
I then made a template for the motherboard, and proceeded to mount the board onto the plate:
One can see that there is a very fine gap between the board and the side panel:
I mounted the buttons which I will use as the power and reset switches, and yes... They will glow yellow...
More content soon to come...
Link to comment
  • 2 weeks later...
Side fans are now mounted:
Another angle of the intake fans:
Power supply, Cooler Master 650W, has been modded to have a yellow fan to match with the theme:
A 20mm bullet from a machine gun on a helicopter, just the shell of course, but will be inserted inside of the chassis to add effect:
Take a look at the clearance within the chassis of the hard drive, relative to the power supply and case fans:
Link to comment
How the :) did you get that ammo box!? I want one! Please!? Will be keeping a close watch on this! Update! Update! Update!  :D
Thanks man!  :D  I found the ammo box in South Africa, where I am based, and I got it from a Food Lovers market, where they have many various types of foods for sale and I knew that this needs to be a computer when I saw it  :D
Link to comment
I took the Cooler Master logo off of another cooler master chassis, then added it onto the power supply:
The Gigabyte GTX460 Superclocked Edition 1GB DDR5  :D
Prepping the side panel for the USB ports:
This is the bottom piece of the front panel of a Cooler Master chassis, using it for the USB panel:
Link to comment
Haha! That's awesome! I have been seeing A LOT of military themed case mods, but this one got my attention. I have a suggestion. Use dead land mines for the feet! XD
Looking forward for the finished build! And by the way, I just noticed, we have a common don't we? :P
Link to comment
  • Create New...
Important Information
