VALKYRIE Posted July 7, 2015 Author Share Posted July 7, 2015 Hi there, I plan to swap the motherboard tray with the latest motherboard tray revision I did, it is better for heat transfer purposes to have a fully solid motherboard tray without cut out for the CPU because there is wider increased area of contact between the motherboard and motherboard tray, I need to remind you I place a thermal pad 4mm thick between the mobo and the mobo tray to avoid short circuit damage and the standoff/spacers have been reduced from 8mm to 4mm Link to comment Share on other sites More sharing options...
VALKYRIE Posted September 18, 2015 Author Share Posted September 18, 2015 Update:, I plan to swap the CPU cooler with the Evercool Silent shark, using the vertical airflow of the case to cool down this CPU cooler, I rotate this cooler in the way is shown in the pictures below, in this way the speed of the ascendant airflow moving parallel to the towers is greater because this cooler has lower impedance if the airflow is parallel to the towers and not perpendicular to the towers, some modifications of the cooler itself are necessary obviously Airflow Impedance of the CPU cooler is a feature of the cooler which show us how much the fins of the cooler are blocking the available airflow to go through the cooler itself Airflow Impedance = pressure drop through the cooler.http://www.arx-group.com/airflow1.html Link to comment Share on other sites More sharing options...
VALKYRIE Posted November 1, 2015 Author Share Posted November 1, 2015 The Evercool Silent Shark CPU cooler is here, now I need to modify a bit this cooler before installation Link to comment Share on other sites More sharing options...
VALKYRIE Posted December 6, 2015 Author Share Posted December 6, 2015 Finally I got an idea how to remove the side bended edges of this cooler without damaging too much the factory look, this modification allows the airflow to go through the cooler from this side instead of the normal side Link to comment Share on other sites More sharing options...
VALKYRIE Posted January 10, 2016 Author Share Posted January 10, 2016 Hi, almost finish the swap of the CPU cooler, I am going to test if this Evercool Silent Shark is better or worst than the Scythe Mugen 3, Update: The temperatures results with the Evercool Silent Shark were struggling to match the results of the Scythe Mugen 3, at the moment the only reason I can think about is because the Evercool don't have the extra small aluminium heatsink at the base of the cooler like the Scythe Mugen 3 has, therefore I got already from eBay a small aluminium heatsink to attach to the base of the Evercool Silent Shark, there is a bunch of modifications I need to do, I need to modify completely the way the Evercool is attached to the CPU, below I add some photos Link to comment Share on other sites More sharing options...
VALKYRIE Posted September 5, 2016 Author Share Posted September 5, 2016 Hi, I decided to add another two cut outs to the motherboard tray just in case eventually in the future can be needed for various sort of motherboards configuration, also have changed the location and shape of the cut out to pass the cables through the feet of the case, below are shown some photos Link to comment Share on other sites More sharing options...
VALKYRIE Posted March 18, 2017 Author Share Posted March 18, 2017 Hi there, a bit of time available now to do some case modifications, I order the metal work factory to modify again a bit the case feet and also the cutout of the motherboard tray, the latest case feet will be made with Stainless-Steel 3mm (bullet-proof) thick, which is harder and stronger than usual mild steel, I reduced the height of the case feet by 20mm = 2cm, the original design was 100mm height, therefore now the whole case will be above the floor by just 80mm, I think this is still enough and not too close to the floor to hinder the airflow to enter the case through the case bottom, below some photos of bending/fold process at the metal factory Link to comment Share on other sites More sharing options...
VALKYRIE Posted March 23, 2017 Author Share Posted March 23, 2017 Hi there, Yesterday I bring home the new revision of the case feet made of Stainless-steel 3mm thick, hopefully this weekend I can drill the holes for the screws, I attach below some photos for comparison between the new and the previous design of the feet which were made of normal mild steel 3mm thick Link to comment Share on other sites More sharing options...
VALKYRIE Posted March 24, 2017 Author Share Posted March 24, 2017 Hi there, today at the metal work factory we finally bend the latest revision of the motherboard tray and squeeze together the self clinching flush nuts for the ATX standoffs, later after I drill some holes for the screws, I still need to bring the various case components for the electrostatic powder coating Link to comment Share on other sites More sharing options...
VALKYRIE Posted June 4, 2017 Author Share Posted June 4, 2017 Hi, finally the metal work factory has made me the new modified brackets for the CPU cooler, I just need to make some holes on the aluminium heat sink for the screws, some photos below, thanks for watching Link to comment Share on other sites More sharing options...
