chitoz Posted March 1, 2015 Author Share Posted March 1, 2015 so its time to make holes Link to comment Share on other sites More sharing options...
chitoz Posted March 1, 2015 Author Share Posted March 1, 2015 so hard -.- to have near perfect measurements .So i drilled holes for the brakets . Make them straight as possible. Took 2hrs just to make them straight. And some problems was solved. I used groments coz its fast to install and it has a low profile it to it. I was going to place m4 threads but i soon realised that there is an easy and fast way to do it. . 20150120_180824 20150120_180835 20150119_215640 20150120_203917 20150120_204629 Link to comment Share on other sites More sharing options...
chitoz Posted March 1, 2015 Author Share Posted March 1, 2015 So i drilled holes for the brakets . Make them straight as possible. Took 2hrs just to make them straight. And some problems was solved. I used groments coz its fast to install and it has a low profile it to it. I was going to place m4 threads but i soon realised that there is an easy and fast way to do it. If m4 srews are better . Just comment bellow coz ill change everything 20150120_210203 20150120_214115 20150123_210213 20150120_214142 20150123_205056 20150123_205125 20150123_224805 Link to comment Share on other sites More sharing options...
chitoz Posted March 1, 2015 Author Share Posted March 1, 2015 more pics . and yes that's a 120mm fans there ,case is at 2.8feet by 2feet by around 1feet . it will still be bigger around 3feet and i made my frame a bit clean 20150125_204707 20150129_172045 20150129_172029 20150129_172111 20150129_172102 20150129_172102 20150129_174810 20150129_174906 20150129_174844 20150129_174823 Link to comment Share on other sites More sharing options...
chitoz Posted March 3, 2015 Author Share Posted March 3, 2015 i would like to thank again to bitspower and avexir Link to comment Share on other sites More sharing options...
chitoz Posted March 7, 2015 Author Share Posted March 7, 2015 bought some items for the modding . 20150301_134911 by christian_1550, on Flickr Link to comment Share on other sites More sharing options...
chitoz Posted March 7, 2015 Author Share Posted March 7, 2015 so my girlfriend give me her very old computer . i was happy when opening it becuase some of the parts here are so old i didn't see it yet. like the lower portion in the mobo, DDR1 ram . and a cpu cooler branded by Intel and the cpu is and AMD learned a little from the process of dismantle the pcs 20150303_203047 20150303_203336 20150303_203633 20150303_204251 20150303_205109 Link to comment Share on other sites More sharing options...
chitoz Posted March 7, 2015 Author Share Posted March 7, 2015 my goal in the old case was just this i lower the resolution at this part so that for slow internet ones can easily open the pic or see . 2048x1536 from 4128 x 3096 20150306_201540 Link to comment Share on other sites More sharing options...
chitoz Posted March 15, 2015 Author Share Posted March 15, 2015 So im back to modding . Busy weeks because of graduating so i cut some pcs of aluminum braket for the support of the placements of the mother board and the parts.after cutting. i measured it and This is how i measure where the brakets in the case go so that i have a guild where to place it i know its hard to understand it. Sorry 20150315_143807 20150315_160649 by christian_1550, on Flickr Link to comment Share on other sites More sharing options...
chitoz Posted March 15, 2015 Author Share Posted March 15, 2015 I made the brakets straight edges as possible . Sand it. And so on drilled holes At the frame and the newly cut aluminum braket. One hole is done now for the 3 remaining holes . Sorry. For no pictures how i drilled it btw its so hard -.- because you need to hold it upwards and side wares in order to drill it and the right place for making the hole 20150315_171344 Link to comment Share on other sites More sharing options...
