Jump to content
Project RED TIDE
chitoz
  • Replies 73
  • Created
  • Last Reply
UPDATES  : god i really need tools -.- like dremel   hope my rig goes well i surely need dremel that much cant take my grinder in small edges :) i need dremel . -.- so i search for acrylic glass and found  out is around $50 for a 6mm acrylic so freaking  expensive for me . and  12mm for $100 and i got around $160 here and sitll need to buy many parts -.-
Link to comment
Just a little updates. So i noticed that on the lower portion of the case is just small and maybe iy cant handle the weight of the case. And maybe the screws wont fit. So i decided to replace the small angel brakets to a bigger one . So this is before and after
Link to comment
so im finding a spot for the psu  . and found out theres a aluminum bracket blocking the way so cut cut cut
16893461669_c183a9bc6a_k.jpg20150407_130845
16457221774_3504c6d0fd_k.jpg20150407_133620
using dremels  flex Shaft
16891886698_7c0de4a32a_k.jpg20150407_151540
done cutting wooh . took me around 30mins to cut this thing
2 cutting disk are broken after cutting this  :(
16891873298_83620b119c_k.jpg20150407_154848
so i recycle my mistake aluminum bracket  and created a support for the psu   if your asking why i put support rather that just place it down in the aluminum well ill be placing fans on the bottom for the  air to get in or out in the lower portion of the case
16457201274_6b9e266bfd_k.jpg20150407_154912
so it fits
17079651965_3962c79cad_k.jpg20150407_154944
this is the aluminum support for the psu . works good but i  think its small and it needs to be big ;)
Link to comment
  • Create New...
Important Information
