Jump to content
Maco Cortes
Hi. This is the final output of the PRISM, but in an MATX form.
I came up with this idea, and hoping to make this as a replacement for the GOLIATH. Why? Goliath is a bench, and it is prone to foreign objects. Prism would maintain the minimalist design and will be watercooled since airflow is slightly compromised. The case is perfect for me. It's not that bulky, it's not that small.
HEIGHT: 435.5mm
LENGTH: 470mm
WIDTH: 150mm/250mm with feet
FORM FACTOR: MATX
Materials:
Tempered Glass
Acrylic / Plexiglass
Aluminum Sheets
Aluminum Tubular Bars
Aluminum Angle Bars
10917943_1554189934821518_95167218176166
10934094_1554189701488208_35157023542826
10929110_1554189718154873_75760295977736
10927861_1554189714821540_53635023075969
10847661_1554189851488193_66329493490421
10911387_1554189828154862_83427420623832
10924226_1554189854821526_76054972546707
10830946_1554189918154853_57929795701390
Link to comment
  • Create New...
Important Information
