Jump to content
Project WoodChuck: The dual system watercooled cabinet
flatoutnos
THIS IS NO LONGER DUAL SYSTEM! IT IS TRIPLE SYSTEM
This is a triple system that will feature one whole custom water cooling loop. The case is a custom wood cabinet that I am building to house everything. The color scheme is black/white/green.
Specs:
system 1: 5820k
                msi x99 sli plus
                Cooler master V750
                GTX 980 sli
                16GB kingston ram
                3TB Seagate HDD
                1TB Toshiba HDD
                1TB WD blue HDD
                250GB OCZ SSD
                128gb kingston m.2 ssd
system 2: 4460
                z97-a
                8GB Samsung RAM
                GTX 660
                Corsair CX 750m
                750gb HDD
                240gb pny ssd
system 3
               4790k
               gigabyte h81 motherboard
               16gb pny ram
               200gb OCZ enterprise ssd
               2tb hdd
               1tb hdd
               1tb hdd
Water Cooling: EKWB for CPUand the GTX 980's
                        Magicool 240mm rad
                        '99 Honda Civic rad
                        Koolance PMP 450 pump (x2)
                        PrimoChill flex tubing
                        xspc fittings
Cabinet: Knotty Pine wood
              plexiglass
              aluminum
First thing I did was make the plans for what I wanted to do
Next thing I did was get all the wood together and start cutting and putting it together.
Next I sanded the legs I took from a previous cabinet and painted them.
Then I put them on and added a drawer.
Now I cut all the holes for plexi, rads, optical drives, etc.
I bought some paint and painted my waterblocks, rad, psu, optical drive, hdd, and ram. Still have some touching up to do but thats for another day.
Link to comment
Update:
I put the floors in and put in the front I/o
I cut out the back panel so I can access my motherboard from behind and all the cables
I added in the motherboard tray
I got my Motherboard back from Asus and I painted the heatsinks and ram to match my build
I changed the motherboard in the second pc so I could put in a gtx 660 along side my ceton infintv 4
Tomorrow I will sand down some areas of the wood and cut out for the motherboard and power supply
Link to comment
  • 3 months later...
Update:
I painted my power supply and other things
I took an old thermaltake case and chopped it up for my motherboard tray
Next I cut a hole for the tray
I painted it white
Painted some Hdd's too
Got it mounted
Put my key start on
Motherboard for the server
Mounted some more items
Test fitting my motherboard
Mounted pump and reservoir
Mounted radiator
Added a second pump and connected them in parallel
Added fans to the radiator
Added some trim around radiator and test fitting some glass
Painted the gtx 660 for the streaming pc
Made a cover for the I/O
Made a cover for the back and added trim
Added dowels for the top cover
Made a window with trim for the lower compartment
Added trim around the windows
The 200gb enterprise ssd for the server arrived
Stained it and added the rear part for the motherboard
New ssd for the main pc arrived
More pics of it stained
Put in the bottom pc
Had an accident! Had to buy a new 4460
Had to swap the server and streaming pc because I mis-measured the PSU
Started bending the tubing
Added the nzxt hue
More pics of tubing
Mounted my hdd's and an ssd
Mounted the motherboard tray
Added the streaming pc motherboard
Added in the main PC
Added the power supply and did some wire management to the streaming pc
Added a trim piece to the front of the radiator to prevent it from falling out the front (the piece came from the paneling in my house since we remodeled)
Finished the loop up top
I flipped the radiator around
More pics of it
Filled it with liquid
Stained the front piece
Added the handle
Some almost finished pics
RIP. It exploded, noob mistake. Air rises to highest point in system and since not all the air was out, this was the highest point and it since my system was on it heated up the tubing and it exploded. I had to replace the motherboard and graphics card barcause of this.
Replaced the 980
I replaced the tubing with something that was familiar to me, soft tubing.
Second 980
Added wheels to replace the legs
Mostly finished but since I hadent had a pc in months, I used it like this for a few weeks.
I finally finished it and detailed it.
Link to comment
  • Create New...
Important Information
