Alucard Posted February 1, 2015 Author Share Posted February 1, 2015 This is the final look of the motherboard cover. i liked the white frosted look, but i decided to use a carbon fibre sticker Link to comment Share on other sites More sharing options...
Arcis Modz Posted February 1, 2015 Share Posted February 1, 2015 nice work man.. looking forward to that custom block. Link to comment Share on other sites More sharing options...
Alucard Posted February 1, 2015 Author Share Posted February 1, 2015 nice work man.. looking forward to that custom block. Thank you Andrew Link to comment Share on other sites More sharing options...
Alucard Posted February 16, 2015 Author Share Posted February 16, 2015 Hi everyone. after quite some time. here with the custom block on the cpu. first of all i should say that this block didn't have a significant temp difference than an air cooler. but it was a test run without using a rad, just connect it to a pump and connect the pump to a res. inlet for the res is a tap and outlet from the block just goes out to the sink. Link to comment Share on other sites More sharing options...
Alucard Posted March 11, 2015 Author Share Posted March 11, 2015 Hi Modders, here's the starting of metal work that i did for the build. first i made using mild steel but it was too heavy, so here it is in Aluminium. All cust by Jigsaw and Dremel. As you can see the side panels didn't fit well. so i had to change the design to some extent. So the internal structure is like this... but the mobo tray is not inverted. Link to comment Share on other sites More sharing options...
MACIEL BARRETO Posted March 11, 2015 Share Posted March 11, 2015 very good loved the case design Link to comment Share on other sites More sharing options...
Alucard Posted March 11, 2015 Author Share Posted March 11, 2015 very good loved the case design Thank You Maciel Link to comment Share on other sites More sharing options...
Alucard Posted April 17, 2015 Author Share Posted April 17, 2015 Hi Guys, So this is the final update. So after assembling all the parts i took them apart and painted with black and Gigabyte Orange. And here's are them Then back to assembling all of them. So when i left home back to my hostel it looked like this I didn't like the front panel that much Got a new PSU. COOLER MASTER Thunder M Modular, aesthetic and cheap I did a little redesign for the front panel. this is the final look of the build with LED lights on Link to comment Share on other sites More sharing options...
Alucard Posted April 17, 2015 Author Share Posted April 17, 2015 A big thanks goes out to Gigabyte. If not for them this build would not reach this level. Thank You Very Much Link to comment Share on other sites More sharing options...
Alucard Posted April 17, 2015 Author Share Posted April 17, 2015 Final Pics of the completed build guys. Might add few more parts to the build and then i will update. but until then this is the final look. Link to comment Share on other sites More sharing options...
