Max Phang Posted February 1, 2015 Share Posted February 1, 2015 Hello on this Worklog and to be honest,This is my first time modding a case,and due to the fact i can only start when i receive the parts i need in this post so here is what i would need. processor : I7 5930k Motheboard : Asus x99 deluxe GPU : 2x GTX 980 (in dual sli) Ram : 2x Corsair Dominator platinum 16GB (4 X 4GB ) Storage - 2X Intel 730 series 120 GB SSD (Raid 0 / Boot Drive) - 2X Western Digital 6 TB (Green) Power Supply : Corsair AX1500I Case : Cooler Master Cosmos II Fan Controller : Lamptron Fc touch Cooling: CPU Water-block : EK Supremacy EVO GPU Water-block :2X EK FC-980GTX Fans : 7X Cooler master Jetflo 120mm Fans Radiator -EK-CoolStream-RAD XTC Triple 120mm series -EK-CoolStream-RAD XTC Double 120mm series Pump 2X :EK-DCP 2.2 reservoirs : EK-Multioption X2 reservoirs (Advanced Version) Tubing : Clear Rubber Tubing\ Fittings : EK PSC FITTINGS (Black) END I will post more if i manage to get the parts Link to comment Share on other sites More sharing options...
