Jump to content
So, time to end the contest less and less.
Today I'll show you one of the hallmarks of my modding project. How did Ken Block in the car, I use in my scratch build a real carbon fiber! Not film, not laminitsiyu, present 2mm thick carbon fiber! The plans were engraved, but as long as it will not be.
Also, I came to the details carved into the laser alloy of magnesium and aluminum (AMg5) with a thickness of 2.5 mm
Front panel with holder
Bottom
Back panel
Top panels. On one of them will stay watercooling radiator
The average wall and holders for HDD and SSD
"Gills" and carved brackets
This item will be a support for the handle housing. It is made of duralumin on CNC machines
The project will be used ISO 7380 M3 bolts of stainless steel and high-strength varying lengths
And it's not sand - is powder paint for the frame. Color chose the catalog closest to the color wheel on the [HOONICORN]
If you think that the real carbon and fog machine - the most interesting things in this project - you are wrong - the most interesting thing to come!
Ready to Rock!
Link to comment
Top panels and radiator are mounted on spacers. I made them by hand from L-shaped aluminum corner. Now I want to tell you how to make a strong thread in aluminum, using special threaded rivets. How does this rivet can be seen in the previous report. She is standing on a sheet of carbon
I do holder.
I increase the hole to 5.2 mm (M3 thread)
I reams shallow drill holes 8mm shallow
Try on. This is not the best hole in the frame to get a lot better
Need a special Riveter
Spun rivet
Puts in place
Pull and outcome.
Also from the L-shaped corner I was made brackets for doing the motherboard tray. The two of them grew stronger conventional rivets to the rear panel.
There are all top brackets
And for mb tray
Fold the holders HDD and SSD, and gills
The frame is ready. Bottom to attach to it using bolts and rivets.
Link to comment
As I promised, interesting things of my project:
1) Headlight. Yes, yes, inside mITX case. Not from the Mustang, but also the classic car! These lights are put on the VAZ 2121 Niva, Vaz 2001. Lights of the same size (170mm diameter) is also set to MB Gelendwagen, VW Golf 2 and other cars, including the Mustang.
VAZ 2121 NIVA
The cartridge and the LED for illumination
2)Carrying handle made of solid duralumin. I wanted to do it in the style of the control knob on the handbrake drift - cars.
Not by car of Ken, but as Vaughn Gittin Jr.'s Mustang RTR 2015 Spec 5.
http://www.speedhunters.com/2014/11/2015-ford-mustang-rtr-spec-5/
Source of inspiration
The handle holder will be in the form of a spring, then with the handle it will look like suspension push-rod.
Stickers
Carbon sheet cut into CNC MILLING of the desired size.
The other side, it is clear that this is a real carbon
Link to comment
  • Create New...
Important Information
