KeelinTy Posted February 6, 2015 Share Posted February 6, 2015 Project Koalafied: Description: Using the latest model of the CoolerMaster HAF 922 and cutting out the side fan grate for a window. Then after cutting out the spot for the window, set it up for a glass window. After setting it up, make sure you can still get the window out so later on you can chance between different color glass. After Adding the window to the case, add an LED strip on the inside and have it connected to a contoller in one of the 5.25 drive bays. Hook everything up and then done. Hardware: CPU: Intel i7 4790K @4.9ghz Motherboard: Asrock Fata1ty Z97 Killer RAM: Kingston 8gb DDR3 x2 (16gb total) GPU: Sapphire Radeon R9 270 OC x2 in CrossfireX CPU Cooler: Corsair H60 (Modded with 2 Arctic High Performance Fans. Idle temps around 29 C ) PSU: XFX Pro 750 Watt Black Edition Fully Modular Power Supply HDD: WD 1TB Blue Case: CoolerMaster HAF 922 LEDs: NZXT Hue RGB LEDs Fan Controller: NZXT Sentery Mix 2 Fan Controller Video Jan 16, 7 28 31 AM.mov Link to comment Share on other sites More sharing options...
