Tomma.PB Posted February 7, 2015 Share Posted February 7, 2015 Long time ago, i have an idea for modify a case as bugatti, thanks for cooler master give me this chance to finish this work. this is the spec list. Did a little work for the fan to test the visual effects, cooler master jetflo 120. New tools, very good. Link to comment Share on other sites More sharing options...
Tomma.PB Posted February 16, 2015 Author Share Posted February 16, 2015 change the fan's color, cause of i think the orange looks like very young....i change to mate black , and later will put a little orange color on that. cut the plate for the motherboard plug put into the naked case. cut a plate to test the size for the inside cut a acrylic plate. use spare motherboard to test back cover is done Link to comment Share on other sites More sharing options...
VALKYRIE Posted February 17, 2015 Share Posted February 17, 2015 Good idea , where you plan to install the power supply? Link to comment Share on other sites More sharing options...
Tomma.PB Posted February 20, 2015 Author Share Posted February 20, 2015 Good idea , where you plan to install the power supply? thanks, psu will be back of the radiator . Link to comment Share on other sites More sharing options...
Tomma.PB Posted February 20, 2015 Author Share Posted February 20, 2015 did some covers job. and, cut the front cover. Link to comment Share on other sites More sharing options...
Tomma.PB Posted February 20, 2015 Author Share Posted February 20, 2015 start the side panel work. take whole night to cut the acrylic plate...still not finish. Link to comment Share on other sites More sharing options...
Tomma.PB Posted March 7, 2015 Author Share Posted March 7, 2015 took a long time to find a kind of material to modify the front panel. finally i got it. test vinyl , i dont want to use a lot of carbon vinyl, just use it to cover the keyboard, maybe use it for some small things. Link to comment Share on other sites More sharing options...
chitoz Posted March 7, 2015 Share Posted March 7, 2015 nice build i like the side panel the color looks hot Link to comment Share on other sites More sharing options...
Tomma.PB Posted March 8, 2015 Author Share Posted March 8, 2015 front cover is done, next step is the back panel and side panel. Link to comment Share on other sites More sharing options...
Tomma.PB Posted April 29, 2015 Author Share Posted April 29, 2015 nearly finish , did a lot of work Link to comment Share on other sites More sharing options...
