Buckroger Posted March 1, 2015 Author Share Posted March 1, 2015 Hi, Being bz with work.. Not much going on.. Also no idea which 360 rad im going to use.. Thanks for stay tuned.. Will update more tonite Link to comment Share on other sites More sharing options...
Buckroger Posted March 2, 2015 Author Share Posted March 2, 2015 got my self another piece of acrylic to attached the reservoir, fitted just nice ,, forgot about pump. not sure where to place the pump, loop arrangement also driven me crazy . thinkin of using acrylic tube with multi adaptor. but, no budget wish i had a sponsor for that Link to comment Share on other sites More sharing options...
Sunday Morning Posted March 2, 2015 Share Posted March 2, 2015 buahahahah try ask cooler master malaysia le .. probably they can help you out Link to comment Share on other sites More sharing options...
Buckroger Posted March 2, 2015 Author Share Posted March 2, 2015 donno how to ask der .. Link to comment Share on other sites More sharing options...
Buckroger Posted March 10, 2015 Author Share Posted March 10, 2015 am waiting for my fitting. hopefully it will arrive very soon. Link to comment Share on other sites More sharing options...
Buckroger Posted March 14, 2015 Author Share Posted March 14, 2015 Got my parcel today . here is what inside Tadaaaaa!!!!!!! after fit in those fitting i also testing pc lightingto check which areais the best to position the led and the fun begins : Sorry for the bad image quality, am using phone camera. trust me it looks very much better with DSLR Link to comment Share on other sites More sharing options...
Buckroger Posted March 15, 2015 Author Share Posted March 15, 2015 got this to fixed in the table casing, unfortunately the radiator is too thick. need to find the slimmer one. 360 Radiator will be halt until i manage to get the slimmer radiator. meanwhile... am testing for leakage, no leak were observed! . Link to comment Share on other sites More sharing options...
Arcis Modz Posted March 17, 2015 Share Posted March 17, 2015 hey bro. where did you grab those fittings and acrylic tube? your also here in malaysia right? btw. looking good so far. keep it up. Link to comment Share on other sites More sharing options...
Buckroger Posted March 17, 2015 Author Share Posted March 17, 2015 Hello there, That is barrow fitting got it from AliExpress & acrylic tube i got it from local acrylic shop. Yup! im from Malaysia too.. Thanks.. Link to comment Share on other sites More sharing options...
Arcis Modz Posted March 18, 2015 Share Posted March 18, 2015 thanks for the info bro. Link to comment Share on other sites More sharing options...
