Jump to content
CM Build Cosmos II - Project Minimal
CircularCore
Hello everyone.
My name is Giulio A.K.A CircularCore , and I'm an Italian Modder.
I want to present my new project,as the title suggest is based on elegance and minimalism.
Hardware Specs:
Intel I5 4670K
Asus Sabertooth z87
Kingston HyperX Fury white 16gb 1866
SLI GTX 670 Direct CU II
Cooler Master V850
SSD X2 Kingston Hyper X 3K 120GB Special Edt. White (RAID0)
Asus ROG Xonar Phoebus
Cooler Master Cosmos II
Liquid Cooling Loop:
FAN:2xCorsair SP120 1x Corsair AF120 QT EDT. 3X Alpenfohn Wingboost White
CPU Block:EK Supremacy EVO Clean Plexi Nickel
GPU Block:EK Full Cover GTX 670
RAD:1xAlphacool XT45 240mm, 1X Alphacool UT60 360mm Special Edt White
RES:Ek Res x3 250
Pump:EK D5 Vario
Pump Top-EK D5 X-TOP Clean Plexi
Tubing:E22 Rigid Acrylic tubing
Fittings:14x Ek 12/10, 6x Bitspower Rotary adapter 90°,1x Bitspower rotary extender
Coolant:Mayhems Pastel White
Controller:Lamptron FC5 v2, Pump Koolance CTR-SPD1224
Device:
Sony KDL-32W705B
Steelseries Sensei
CM Storm Mech
MAIN SPONSOR
bpakMWd.jpgR0UoVG8.jpg6yVSJFO.jpgGEUTdTv.jpgmjCeS9A.jpgmFdhH2A.jpgnk0xpSt.jpgxYbrB7i.jpg7yLsT7m.jpgFuHFOlf.jpgOhDGSQQ.jpgKgzTxWh.jpgwXTiJQS.jpg
Link to comment
  • Create New...
Important Information
