Pclinde Posted April 28, 2015 Share Posted April 28, 2015 Nice mod so far! I love the Hyper Beast memory. Cheers, Pim Link to comment Share on other sites More sharing options...
jojoharalds Posted May 18, 2015 Author Share Posted May 18, 2015 Thank you . Link to comment Share on other sites More sharing options...
jojoharalds Posted May 18, 2015 Author Share Posted May 18, 2015 Package Time !!! Bitspower Fitting adapters white, and Koolance INS-FM17N Flowmeters Link to comment Share on other sites More sharing options...
jojoharalds Posted May 18, 2015 Author Share Posted May 18, 2015 Painted the bottom 140mm silverstone fan frame will keep the bladeas it is for now :-) Link to comment Share on other sites More sharing options...
jojoharalds Posted June 2, 2015 Author Share Posted June 2, 2015 And 2 panels are painted and readdy to be installed on the case again, now i am waiting for some more stuff to arrive,(meanwhile painting the third one) the fourth will be custom made due the radiator placement. Stay tuned. Link to comment Share on other sites More sharing options...
jojoharalds Posted June 4, 2015 Author Share Posted June 4, 2015 PACKAGE TIME!! Recieved a small package of some fittings and temp sensors from Performance-Pcs.com today. Most of the fittings i have recieved lately for this project are mainly for this one purpose. (check ou the Picture ) This is mainly for estathics and not for performance or purpose. Hope you like it Stay tuned for more. Link to comment Share on other sites More sharing options...
jojoharalds Posted June 5, 2015 Author Share Posted June 5, 2015 Still working on this panel, Started on two cutouts for windows,wich will be made with smoked tempered 3mm glass. i also would really much like to install a few digital meters, Flow sensor Display, leak seansor display, and of course temp sensors with display. But we will see what is possible without making it crouded. Link to comment Share on other sites More sharing options...
Pclinde Posted June 9, 2015 Share Posted June 9, 2015 Little gorilla's for the win! That BitsPower collection looks yummy, especially the two last photo. Link to comment Share on other sites More sharing options...
jojoharalds Posted July 4, 2015 Author Share Posted July 4, 2015 The panels have almost all been painted. Working on some routing of the watercooling loop and partplacement Waiting on sleeved cables (since it is a modular psu it will be a full set ,not extensions) Test fitting a loop with acrylic pipes first Since i need some tools for copper first. Then next week i am hopefully able to make another order for fittings and adapters. This will get the project moving . Then i have to shop for the window parts.....and some acrylic to make the inside more clean. These are the plans so far. Just wanted to give those of you hwo follow a short update so you know that i havent give up on it. ☺ Stay tuned.. Link to comment Share on other sites More sharing options...
jojoharalds Posted July 18, 2015 Author Share Posted July 18, 2015 Sponsorship package from icemodz.com These look awsome like always,still missing some cables though,wich will come in the near future. also haven´t decided on Gpu yet,(so for the time beeing i will just be going with the onboard gpu. (wich performed alright after some tweaking and overclocking) And i also started on the loop (trying to make it look clean and easy swappable for the gpu ) Have a nice weekend all of you This post is sponsored by Link to comment Share on other sites More sharing options...
