Ilija Dakic Posted April 13, 2015 Author Share Posted April 13, 2015 Ok guys, i just finished some work on my 3d Model for tonight It is to scale https://skfb.ly/DOwD Also the Video of an open case model on youtube Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 14, 2015 Author Share Posted April 14, 2015 Ok, i made back panel now for the radiator and hard drive area i made a sandwitch of two pieces of aluminum sheets folded them in the way i needed them and stuffed them with thermal isolation that will help muffle the sound as well and made entire thing really sturdy at no weight cost As for hard drive mount, i will make a sort of floating floor for almost complete vibration reduction, it will be two sheets of aluminum, bottom one mounted, than spounge in between 10mm thick and another aluminum sheet on top of it, connected to the bottom with rubber going all around it Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 15, 2015 Author Share Posted April 15, 2015 Working on fan grill design turned out to be more complicated than i thought Here is what i have for now... still need to figure out few more details Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 16, 2015 Author Share Posted April 16, 2015 Rad grill done, if anyone likes/wants this, or stuff like this, i got few designs i made for now and for later on with new projects, you can just PM me/ email/ or reply they are .crd and ready for laser cutting in scale for 240 rad ( two for 480 ) Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 18, 2015 Author Share Posted April 18, 2015 Ok, i finished wrecking my old Chieftec Aegis case to scrap here is what the backplate looks like nicely sanded ( i hand sanded it :/ ) and in its new home also, i will need to cut the hole for the cpu cooler mount and so i can put a 92mm fan back there.. it helps allot with chip cooling i also added mesh to the PSU tray And something i think could be really nice if i manage to do it properly Kinda odd that the PSU case is perfect dimensions to host 2 3.5" hard drives and 80mm fan Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 20, 2015 Author Share Posted April 20, 2015 Ok, so i tossed everything on so i can see how it looks and my dog came to inspect it... if she could, she would have gotten her self inside in no time ( i gotta post video of us trying to get her out of the car ) *the red thing on the top is from my old sidepannel, will use it later as a mesh for somewhere Also i started doing some work around the cabbin, this is first look, i need to straiten it before i can use it... it will only be a mold for bending acrylic glass pannel so it is gonna be entire side bent So what do you guys think? Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 22, 2015 Author Share Posted April 22, 2015 Ok, today i figured out i could have take a cabbinet and modify it for the thing i did in the end It seemed logical to make it like this instead of making it out of 3 parts... Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 23, 2015 Author Share Posted April 23, 2015 Ok guys, today i got my first sponsors, i recieved a nice timely response from Phobya Phobya AlphaCool AquaTuning Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 26, 2015 Author Share Posted April 26, 2015 So today i found out that the box in my wast basement wasnt just an empty box as i tought for last 6 years, inside was mint in box router *idiot right...he..he.....he. * I made cannals for acrulyc window i will be using and it will go here : also i got a bit pissed and redid the rooftop, AGAIN *5th time* ARGHHHH new system for easyer mounting with 2 steel bars... Also, tomorrow, as i found out i have router i will smothen all the edges down and give them nice curvy finish Link to comment Share on other sites More sharing options...
Ilija Dakic Posted April 27, 2015 Author Share Posted April 27, 2015 Today i totally rebuilt the side pannels... one of those days when nothing fits, and i was so angry about it... so i had to do it right this time! I made them from far better quality wood, more precise, with new tools... looks 10 times better and works properly now (the sliding mechanism)... The wood is 10 times better, more compressed, easyer to manipulate. Got a template for 480... and did it right! Smoothen the edges... and the big :) drill for wider and "non-bend" blade for my saw And last, but not least, see the difference!!! Old: New: Also, new sponsor... CoolerMaster.. more details tomorrow ( btw TNX GUYS YOU DA BEST :D ) Link to comment Share on other sites More sharing options...
