Jump to content
Bulldozer project - AMD Tribute
Ilija Dakic
  • Replies 49
  • Created
  • Last Reply
Starting to look good! Good luck with the next steps. :)
Tnx man, here is the update :D
Ok, i know it has been a good long while since i last posted but i am happy to inform you that i am contiunuing my work and that i cleared another year in my faculty :D studying came first to this... sorry :(
I took few of these at local shop here in Serbia ( Uradi sam / Do it yourself )
I cut them to lenght and i made new tracks...
( mind the dog, she is dangerous ) :D
I figured out how to make the windscreen the way i want it to be, also spoon is done tomorrow when i take the rear suspension from Fiat Punto
There is a bit more update some stuff came last week from AquaTuning :)
Tomorrow i will make ubber update!!! I kept you in the dark for far too long :)
Ok, i got few pics of progress and a question :D
The spoon will be simmilar to this but i will str18 it a bit, add some mesh on top, make it more robust with stirofoam and such... it will look really good with suspensions and all painted ;) trust me, i have it in my head!!!
Also  there is a question regarding these two pictures below
Should i make mud protector on the 2nd pic, or should i leave it like it is on the 1st?
Please post coments on what you think i should do and what you like/dislike on it...
Tnx, Bax!
I made a compromis with mud flaps and went llike this, i think you will like it :D
And the demonstration of power!!! :D
Just for you to see how sturdy this thing really is... ( also to mention i am 192cm tall )
I hope you can gasp the sheer size of this thing :D
At some point i will make it battery operated and i will drive on top of it XD
Peeps, i know pictures are awful but my camera bateries ran out :( so i had to use my camcorder.
I know most of you will criticize my choice to go for wood instead of alu but i had my own good reasons :)
Also as you can see, my suspensions came and i am super happy about it :) Deatails almost complete and i hope that tomorrow i will finish complete body and start painting it hehe
  • 3 weeks later...
 here is an update after a big long while
I fixed the doors so they can open correctly now and i had to make them open up top because of clearance issues :/
This is first layer of acrylic filler
This is 2nd, and there might be a tird to fill the smallest holes :)
I've got some stuff inside of the case just to check how everything fits and looks in the cabin :D
I hope you like the overall look inside the cabin :) its a bit tight but I like it like that :) only main ssd's will be inside the cabin, hard drives will go under the entire thing, and under that, radiators, pumps etc :D
Its nearing the end and the start of painting :) i cant show you enough how that makes me feel :D
Also a small adition to everything :) i fixed my speakers that i will be using and i will be also replacing the monitor with 40" 4k display :D
  • 2 weeks later...
Wow, that thing looks awesome! Can't wait to see what it looks like when it's finished :D
Tnx man, and stay tuned :D
A few more days left, I will finish the mod before August :D
As i didnt want to post pictures that make no sence, posting pictures where only i could see the difference, i waited a bit and once i had done things i deem'd made a change, i made a little walktrough around what i have done and around the case...
The video is a bit on the longer side, and i got a bit confused with terminology i would be thrilled if you'd watch it :)
I will grab some batteries for my camera and that is one of the reasons i used camcorder now, and i will take some nice closeups tomorrow, also i will most likely put primer on the drawer piece :)
UPDATE!!!, still not painting :( ran in to some work related issues :P but still sort of big update :)
1)  The "Nose job":
2)  FINALLY! Fan mount...
3) Polyester filler :
Hole for 24-pin done old fashion little plate style with |-type screws :D
It still needs sanding before painting, i corrected the edges and everything on the bodywork of the core part, i got fittings, and i did a hole for 24-pin
  • Create New...
Important Information
