Jump to content
Project: "Fallout 4" Zen-Modz
Zenator
Hello
I'm in the proses of modding my first case. this build is still work in progress.
I have been working on some custom water cooling parts as well as modding the case.
among other mod's, this is a Silverstone FT02 that started off silver.
Parts list:
CPU: I5 4590 @ 3.80 GHZ
GPU: GTX 590
MB: ASUS MAXIMUS VII FORMULA.
RAM: 16GB DDR3-(11-11-11-30) / G.SKILL R.J. @ 2100mhz
PSU: Cougar CMX 1000w
Storage: OCZ agility 3 240gb @ 2tb hdd.
Case :Silverstone FT02
101%20Vault%20plan%20silver_zpsahmz6540.
Thank you for looking, Still working on it.
Hope you like it what I have done so far, a lot more work still to be done.
Cheers, Zen.
Link to comment
  • Replies 23
  • Created
  • Last Reply
  • 2 weeks later...
Hello all, Here is a small update, Added a cover to the GPU to hide the fittings
Gone over the face panel again with with some fin detail and added some matting base paint to all the rust to make it pop a bit more. and scotched some parts of the face panel to dull it up a bit.
Started doing some work on the cover door for the ROG base panel/DVD drive and so on.
Also Getting the vents all painted and bent up. and adding texture too them as well.
Have not had a lot of time to get much more done. but it's all starting to take shape.:)
Link to comment
A bit more progress, Added screws to the side panel, finished the 2nd door. And working on some more weathering textures on the grill to make it look like water has been running off it, that's still work in progress. And added hinges to the grill as well, so I can open it to clean the fan filters.
I did not want to say want I'm trying to build till I knew if I could pull it off. Being this is my Fist try at Modding a PC. I needed to make sure I could make it happen.
Input and feedback is welcome.
Cheers, Zen.
http://www.modsrigs.com/detail.aspx?BuildID=34914
Link to comment
Cats out of the bag.
Link to comment
First Tag plate done. :)
101%20Vault%20plan%20silver%20inside_zps[/url
Hi This one is a bit bigger. 520mm x 180mm.
Been playing on the CNC.
I'm going to be painting it as well but the font Fallout 4 will be lit with LED's
from the bottom. and the rest will be painted to match the case.
the plan is to frame it and mount it to the top of the case like a billboard.
Hope you like it. :)
Again thank you for looking.
Link to comment
I have been using the Dremel at work so far. So was thinking it's about time I got one, And here it is my first ever Dremel. :)
I have been working on the Fallout logo. so have not had the time to do much on the case. but here is where I'm up to with the case. Such slow progress. But I guess in saying that there is a lot to do. :)
Thank you again for looking.
Cheers, Zen.
Link to comment
  • Create New...
Important Information
