Zenator Posted July 26, 2015 Author Share Posted July 26, 2015 Hi again have not had much mod time this week. But here is what I have done so far.Here is a small step by step on the mounts for the billboard for the top of the case. will have two holding it up. I just need to work out the best way to make it work. Here is the back of the Fallout sign, still need to add weather marks but not until the mounts are fitted to it.Here is the face door, its just about done now. Added a spring to the left side to keep i closed. will add a pic for that later as I forgot to take one.Thank you again for look Cheers, Ken. Link to comment Share on other sites More sharing options...
Zenator Posted July 28, 2015 Author Share Posted July 28, 2015 And the rust just keeps going. I going to start calling my self the Rust converter. I think my next build will be cleaner. Thanks for looking. Link to comment Share on other sites More sharing options...
Zenator Posted July 30, 2015 Author Share Posted July 30, 2015 Thanks again for following this build. Would love to know what you think of it so far. All feed back is welcome as always. Cheers, Ken. Link to comment Share on other sites More sharing options...
Zenator Posted August 6, 2015 Author Share Posted August 6, 2015 Hi again, Ok I'm going to be scratch building the Vault 111. the last photo. is the placement of where it is going. This build is all about fallout 4 so adding it to just needs to be done.Going to mach the texture true too the game.Sorry about the super :) photo's Will add better photos later. Just updated to windows 10 and now photobucket. is not working for me. Will be adding more to it then what you see here. And will still be painted in high detail.this is just a Photoshop overlay to show you all where it is going.Thank you Again for stopping buy.Cheers, Ken. Link to comment Share on other sites More sharing options...
Zenator Posted August 8, 2015 Author Share Posted August 8, 2015 Progress report I made a template in Photoshop and printed it to the size I need.Then comes the blade work, there are 4 layers of PVC plastic glued together so I can cut each at a time. Then once done will be sanded and then putty filled and sanded again. No CNC. for this part. all old school. One more for the day, Got it all cut out. and routed out the center with a Dremel with a circle tool. Fist time trying this and I think it work well. Thank you for looking.Zen. Link to comment Share on other sites More sharing options...
Zenator Posted August 10, 2015 Author Share Posted August 10, 2015 Keeping it going, OK have now Putty filed it, sanded, Primed, and dusted.Then I will start fine sanding it, and then finish off the center detail. And then move on to the next stage. The support arms.Thanks Again for stopping by. Link to comment Share on other sites More sharing options...
Zenator Posted August 12, 2015 Author Share Posted August 12, 2015 Center is just about done. Still working on the arms.Thanks for looking. Link to comment Share on other sites More sharing options...
Zenator Posted August 15, 2015 Author Share Posted August 15, 2015 Hi getting closer to finishing the shape of the Vault. still need to add the Valveparts, and add all the bolts. then on to the painting. So for now till tomorrow night. when I add some more photo's here it is so far.Trust me this was slow work. Thanks again for stopping by. Link to comment Share on other sites More sharing options...
Zenator Posted August 17, 2015 Author Share Posted August 17, 2015 Next day update, Going to finish the rest of the modeling, before the next post. And then on to the painting. Thank you stopping by, feed back welcome as always.Cheers, Ken. Link to comment Share on other sites More sharing options...
Zenator Posted August 20, 2015 Author Share Posted August 20, 2015 Hi again Painting is now on. Ill do my best to add pic as I go.The brown is the rust background. will be adding light and dark's to the rust as the blue go's down. as well as the yellow.Thanks again for stopping by. Link to comment Share on other sites More sharing options...
